hgkid1 Offline
#1 Posted : Wednesday, 28 November 2007 12:25:34 AM(UTC)
hgkid1
hey again all
a while back i put up a post about beefing up a 202. thanks to all who replied.
i have sourced an electronic dizzy and a set of genie extractors and am about to get a k&n hi flow filter.
my question is what would be the best choice of carb for this system.
im thinking a 2 barrel most likely so i can get some economy but also have some power when i want it.
also wondering what sort of radiator i should get for the car and is upgrading from the standard water pump a good idea?
also what is a good choice of mild cam?
what should i expect to pay for a set of roller rockers also?
any help will be greatly appreciated
cheers Stuart
Edited by user Wednesday, 28 November 2007 12:29:39 AM(UTC)  | Reason: Not specified
hgkid1 Offline
#2 Posted : Wednesday, 28 November 2007 12:26:32 AM(UTC)
hgkid1
is the carb from a blue motor a good idea?
#3 Posted : Wednesday, 28 November 2007 10:51:59 PM(UTC)
If you want some extra poke with nice fuel economy you cant go past a 186S manifold topped with an XE-XF Falcon Weber carby for a nice all round balance.
Edited by user Wednesday, 28 November 2007 10:52:43 PM(UTC)  | Reason: Not specified
#4 Posted : Wednesday, 28 November 2007 10:51:59 PM(UTC)
If you want some extra poke with nice fuel economy you can't go past a 186S manifold topped with an XE-XF Falcon Weber carby for a nice all round balance.
hgkid1 Offline
#5 Posted : Thursday, 29 November 2007 2:59:39 AM(UTC)
hgkid1
ok and how do i get my hands on these parts? how much will it all cost etc?
HG-PREM Offline
#6 Posted : Thursday, 29 November 2007 3:04:18 AM(UTC)
HG-PREM
Dont go down the road of 350 HOLLEY. Been there done taht on a 202 HQ LS coupe. could not keep the thing in tune. I believe it has something to do with the spring tensions under the mixture screws.
hgkid1 Offline
#7 Posted : Thursday, 29 November 2007 3:07:22 AM(UTC)
hgkid1
ok i also thought of the 350 but apparently its extremly expensive to run.
my uncle offered me a rebuilt one on a manifold for cheap.
whats required to fit it on there other than a manifold? cables etc
HG-PREM Offline
#8 Posted : Thursday, 29 November 2007 3:22:51 AM(UTC)
HG-PREM
off the fire wall, do you have a ridged linkage? or cable set up?
hgkid1 Offline
#9 Posted : Thursday, 29 November 2007 5:42:13 AM(UTC)
hgkid1
umm ridged i guess. its all mechanical.
#10 Posted : Thursday, 29 November 2007 6:01:42 AM(UTC)
What you want is a GTR/186S inlet and WW Stromberg off same. These were standard on some HK-HG so linkages all work OK. Keep looking on Ebay. A 253 red carby will do but will need tuning to suit the 202 (as it was off a 253).
__________________________
adam PERTH Offline
#11 Posted : Saturday, 1 December 2007 9:09:49 AM(UTC)
adam PERTH
or use 2 barrel holley aftermarket inlet with ww stromberg on top.
turn adaptor upside down.
i was very happy with this set up on a mild / warm 186
A1 Bogan.
Pittin Offline
#12 Posted : Sunday, 2 December 2007 12:43:59 AM(UTC)
Pittin
i was told that double strommies were the best and the best cam is out of an gtr xui torana
boom Offline
#13 Posted : Sunday, 2 December 2007 3:10:36 AM(UTC)
boom
i was told that a 4 bbl rochester quadrajet was a good choice
If it doesn’t burn fossil fuels, it’s not a sport.
Edited by user Sunday, 2 December 2007 3:11:17 AM(UTC)  | Reason: Not specified
Guest (6)
