hey again all a while back i put up a post about beefing up a 202. thanks to all who replied. i have sourced an electronic dizzy and a set of genie extractors and am about to get a k&n hi flow filter. my question is what would be the best choice of carb for this system. im thinking a 2 barrel most likely so i can get some economy but also have some power when i want it. also wondering what sort of radiator i should get for the car and is upgrading from the standard water pump a good idea? also what is a good choice of mild cam? what should i expect to pay for a set of roller rockers also? any help will be greatly appreciated cheers Stuart Edited by user Wednesday, 28 November 2007 12:29:39 AM(UTC)
| Reason: Not specified
is the carb from a blue motor a good idea?
If you want some extra poke with nice fuel economy you cant go past a 186S manifold topped with an XE-XF Falcon Weber carby for a nice all round balance. -------------------------------------------------------------------------------------------------- Edited by user Wednesday, 28 November 2007 10:52:43 PM(UTC)
| Reason: Not specified |
If you want some extra poke with nice fuel economy you can't go past a 186S manifold topped with an XE-XF Falcon Weber carby for a nice all round balance. ------------------------------------------------------------------------------------------------- Edited by user Wednesday, 28 November 2007 10:52:43 PM(UTC)
ok and how do i get my hands on these parts? how much will it all cost etc?
Dont go down the road of 350 HOLLEY. Been there done taht on a 202 HQ LS coupe. could not keep the thing in tune. I believe it has something to do with the spring tensions under the mixture screws.
ok i also thought of the 350 but apparently its extremly expensive to run. my uncle offered me a rebuilt one on a manifold for cheap. whats required to fit it on there other than a manifold? cables etc
off the fire wall, do you have a ridged linkage? or cable set up?
umm ridged i guess. its all mechanical.
What you want is a GTR/186S inlet and WW Stromberg off same. These were standard on some HK-HG so linkages all work OK. Keep looking on Ebay. A 253 red carby will do but will need tuning to suit the 202 (as it was off a 253).
__________________________ |
or use 2 barrel holley aftermarket inlet with ww stromberg on top.
turn adaptor upside down.
i was very happy with this set up on a mild / warm 186
A1 Bogan. |
i was told that double strommies were the best and the best cam is out of an gtr xui torana
i was told that a 4 bbl rochester quadrajet was a good choice
If it doesn’t burn fossil fuels, it’s not a sport. Edited by user Sunday, 2 December 2007 3:11:17 AM(UTC)
