3 Pages<123>
#21 Posted: : Sunday, 2 December 2007 7:22:09 PM(UTC)
Scotty
My 2cents worth:
Rebuild the motor as original, using smallest oversizes necessary. Rebuild the heads with hardened exhaust seats (for ULP), standard size valves, new valve springs. Dont polish the heads, leave them as is but clean them up in
#22 Posted : Sunday, 2 December 2007 7:22:09 PM(UTC)
Scotty
My 2cents worth:
Rebuild the motor as original, using smallest oversizes necessary. Rebuild the heads with hardened exhaust seats (for ULP), standard size valves, new valve springs. Don't polish the heads, leave them as is but clean them up i
scottywilkes Offline
#23 Posted : Sunday, 2 December 2007 8:33:29 PM(UTC)
scottywilkes
hey mate thanks for that, but a few questions.
What is better about the blue/black distributor? Ive just installed brand new points which really improved performance as i dont think they had been changed before LOL
Id problably go with the 350 exhau
#24 Posted : Sunday, 2 December 2007 11:05:11 PM(UTC)
Hi scottywilkes
The blue/black distributor (& coil) is a Bosch HEI (High Energy Ignition) system. They have no contact points that wear our & change timing (you just set & forget) & produce over 50,000 volts of spark. If you do lots of kms & dont want
#25 Posted : Monday, 3 December 2007 12:55:58 AM(UTC)
scottywilkes
thanks mate, sounds like il rebuild the waterpump then,
U dont know how much this is helping me out, all the information is GREATLY appreciated. I was searching for stroker kits and came upon this forum and thought i would sign up, turns out its been a
#26 Posted : Monday, 3 December 2007 3:16:18 AM(UTC)
Hi scottywilkes.
Yes, the standard distributor will be fine.
Dr Terry.
#27 Posted : Monday, 3 December 2007 4:41:57 AM(UTC)
On the exhaust, I think the 308 HG GTS had a twin system like the 350 anyway.
Go to Rare Spares and have a look at the woodgrain aftermarket stuff. They are pretty good. If you need a good glovebox lid go looking for someone wrecking a HG Premier.
___
#28 Posted : Monday, 3 December 2007 7:27:17 AM(UTC)
scottywilkes
im not sure on the exhaust, as nan got the exhaust replaced a while back as the stocker well died from old age. Il have a look around, and talk to a few spray painters and parts suppliers, and exhaust store and see what i can do
bundybluedog Offline
#29 Posted : Monday, 3 December 2007 8:36:00 AM(UTC)
bundybluedog
i think twin exaust with the double tips on each was a GTS option for any V8 HT and HG monaro, looks good
jabba Offline
#30 Posted : Monday, 3 December 2007 4:15:07 PM(UTC)
jabba
With the rebuild and cam selection, for on the street I would go with big cubes and the lowest revving spec range you can find. Had an HQ ute which came with 400 cube chev which had been set up for street / strip work. It was next to useless on the str
#31 Posted : Tuesday, 4 December 2007 7:05:47 AM(UTC)
scottywilkes
HAHA NICE. Talked to dad tonight, and supposably, the whole front end of the monaro comes off, looked at the chassis rails, and sure enough, the front end is bolted to the chassis rails, i didnt believe it until i saw it.
Anyway, things that will go a
Edited by user Tuesday, 4 December 2007 7:08:20 AM(UTC)  | Reason: Not specified
#32 Posted : Tuesday, 4 December 2007 7:49:39 AM(UTC)
Hi scotywilkes.
If it was my project, I would forget the stroker kit. Spend your money wisely on other stuff.
You've taken on a very big project. 80% of these are never finished properly, due to lack of money (or lack of interest, due to lack of mon
#33 Posted : Tuesday, 4 December 2007 7:49:39 AM(UTC)
Hi scotywilkes.
Youve taken on a very big project. 80% of these are never finished properly, due to lack of money (or lack of interest, due to lack of mone
#34 Posted : Tuesday, 4 December 2007 7:57:41 AM(UTC)
Hi again.
2 things I forgot.
Make sure the water pump is the correct HT/HG type before you get it rebuilt. The get it rebuilt by a pro, there are only a handfull of guys in Aust that can recon old water pumps properly.
With your brake stuff, same
#35 Posted : Tuesday, 4 December 2007 8:12:19 AM(UTC)
scottywilkes
thanks mate.
Ok il start of by saying, i have decided not to go stroker, and to keep it fully original
The car will be done in stages, first things first, is the engine bay and engine, the motor will get rebuilt, maybe slighly higher comp pistons, a
adam PERTH Offline
#36 Posted : Tuesday, 4 December 2007 8:13:04 AM(UTC)
adam PERTH
Scotty,
i know in previous entries, i told you to shag chicks instead @ 18 years old.
I am sure many of us will agree, attempting full resto on such a valuable asset at 18 years of age may be a bit ambitious.
I know i would have messed it up at 18.
th
#37 Posted : Tuesday, 4 December 2007 8:21:56 AM(UTC)
scottywilkes
hey, i gotto say, i got very ahead of my self in previous posts, all iwanted was power, and forgot about making it nice again.
As it is, its in very good condition, the motor runs strong, yet hard to start and getting tired
The body is generally pr
#38 Posted : Tuesday, 4 December 2007 8:24:30 AM(UTC)
scottywilkes
il drop by with the monaro 1 day and have a talk to that fella mate, and see what he thinks, get him to check the monaro over and get his feelings on the car, if he thinks its a huge task to undergo, il keep it simple, if he thinks its within my standards
adam PERTH Offline
#39 Posted : Tuesday, 4 December 2007 9:05:26 AM(UTC)
adam PERTH
that padgett guy @ coates Hire is a "matching numbers" guy.
he is very fussy too.
i am sure he can help you no end.
ask warren turnbull for a judging sheet, you will see what i mean about having someone with a "holden eye".
A1 Bogan.
#40 Posted : Wednesday, 5 December 2007 2:49:39 AM(UTC)
scottywilkes
im not restoring this for judging, i just want a nice, reliable, fresh car to have as a weekend car. If it turns out good, il proly go into some shows, but most likely just for show, not comps.
The good thing is, this monaro has ALL matching numbers,
Guest (14)
3 Pages<123>
This page was generated in 0.117 seconds.
