#1 Posted : Thursday, 6 December 2007 1:18:35 AM(UTC)
has anyone considered buying a used fork lift or pallet truck to get under the car to work on ? just an idea cheers
adam PERTH Offline
#2 Posted : Thursday, 6 December 2007 1:36:29 AM(UTC)
adam PERTH
good idea for backyarders and paddock work.
May need slippers to extend forks and use acro props for safety.
A1 Bogan.
boom Offline
#3 Posted : Thursday, 6 December 2007 2:39:38 AM(UTC)
boom
seems a bit expensive to lift up your car..........
If it doesn’t burn fossil fuels, it’s not a sport.
adam PERTH Offline
#4 Posted : Thursday, 6 December 2007 3:04:39 AM(UTC)
adam PERTH
$1500?
or a 50HP tractor with forks?
A1 Bogan.
#5 Posted : Thursday, 6 December 2007 6:08:36 AM(UTC)
A 2-pole hoist will set you back about $2000-$2500 installed and certified. 2nd hand of course, 2.5T capacity.
The Yeti Offline
#6 Posted : Thursday, 6 December 2007 11:27:00 PM(UTC)
The Yeti
you should NEVER stand under a load suspended by a forklift, you do realise that a 2.5ton fork lift is rated as such with a 600mm load center (600mm forward of the carraige face) the average over all width of a car is say 2.4m so your load center is at 1.
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
v8cruisin Offline
#7 Posted : Friday, 7 December 2007 12:06:45 AM(UTC)
v8cruisin
I agree with the yeti. It is the load centre you need to remember. might be okay to lift a little bit but I wouldnt be going under it without some sort of support. you can usually feel on a forklift when it is getting to heavy if you lift slowly (being an
