#1 Posted : Friday, 7 December 2007 4:38:36 AM(UTC)
i have a holden 1 tonner and it has small rust patches in it but the worst is just behind the cab on the body rails ,it is also cracking,,,is this common and what is best to fix this
#2 Posted : Friday, 7 December 2007 6:51:09 PM(UTC)
It's normal for a tonner to rust on the tray mount bracket. And yes they crack bad. Especially around the lower control arm rear mount and the shock towers. You can repair it but it may be easier and cheaper to change the chassis. I have a complete rollin
#3 Posted : Friday, 7 December 2007 6:51:09 PM(UTC)
Its normal for a tonner to rust on the tray mount bracket. And yes they crack bad. Especially around the lower control arm rear mount and the shock towers. You can repair it but it may be easier and cheaper to change the chassis. I have a complete rolling
