81837 Offline
#1 Posted : Monday, 10 December 2007 8:40:00 PM(UTC)
81837
I have a 20:1 steering box from a bush wreck I want to put in my HG while I sort out the buggered 16:1. Should it be full of grease? What type? If it has leaked out then I guess the seal down at the pitman arm shaft must be US? The bit of grease in there looks OK and the box seems smooth enough.
80737k Offline
#2 Posted : Monday, 10 December 2007 9:50:56 PM(UTC)
80737k
If it seems smooth enough (read: works well) and it's just till you sort your GTS box then it should be ok for a while. Most steer boxes in use today have never had a spanner on them. I've only ever come across one steer box in my life that was stuffed.
Fossil fuels are YUMMY !
80737k Offline
#3 Posted : Monday, 10 December 2007 9:50:56 PM(UTC)
80737k
If it seems smooth enough (read: works well) and its just till you sort your GTS box then it should be ok for a while. Most steer boxes in use today have never had a spanner on them. Ive only ever come across one steer box in my life that was stuffed.
