6pak Offline
#1 Posted : Thursday, 13 December 2007 5:58:27 AM(UTC)
6pak
Hi folks, I've just finished re-fitting the freshly re-conditioned ram and control valve to my ZD. I just started it and drove it down off the ramps and the steering wheel went nuts! It's turning to hard lock by itself and then when it hits the end of the turn it heads back the other way on its own until it reaches the end of its travel and then heads back the other way and so on. I haven't had a chance to bleed the air out of the system as it was on ramps. Will jacking up the front end and turning it lock to lock to purge the air fix this or this a symptom of something else? I'm starting to wonder if this thing will EVER see the road again!
6pak Offline
#2 Posted : Sunday, 16 December 2007 4:59:12 AM(UTC)
6pak
If anyone else runs into this problem, the solution in my case was to reverse the lines between the control valve and the ram as I had them fitted incorrectly. Ah well, mistakes were made, lessons were learnt. :)
mavman4200p Offline
#3 Posted : Sunday, 16 December 2007 8:38:53 PM(UTC)
mavman4200p
I even posted the photos of mine for you.
Never take
life seriously. Nobody gets out alive anyway.
6pak Offline
#4 Posted : Monday, 17 December 2007 3:39:18 AM(UTC)
6pak
Hi, I initially set it up the same way as yours with the top hose going to the bottom hole on the ram etc. I spoke to the power steering guys who did the work for me once I had problems and they suggested that I had the hoses back to front. I've now got
