seen many of them, they're pretty common as they used them right up to the WH (VX) statesman.
seen many of them, theyre pretty common as they used them right up to the WH (VX) statesman.
You have been a member since:: 2/03/2005(UTC) Posts: 3,135
Most VS3 statos I've seen were the regular VS2 type motor, and I saw my first VS3 179kw only a couple of months ago. I think it may have been cloudy on here who had a HDB 195i VS3???
Because the utes hung around longer than the VS3 stato, you find t |
Most VS3 statos Ive seen were the regular VS2 type motor, and I saw my first VS3 179kw only a couple of months ago. I think it may have been cloudy on here who had a HDB 195i VS3???
Because the utes hung around longer than the VS3 stato, you find th |
Just to add to that. WH was introduced around June '99 VU ute was introduced around September 2000.
Just found the pics of that VS3 stato with the 179kw motor - it's a March '99 - probably one of the last ones.
Mick ___________________ |
Just to add to that. WH was introduced around June 99 VU ute was introduced around September 2000.
Just found the pics of that VS3 stato with the 179kw motor - its a March 99 - probably one of the last ones.
Mick ______________________ |
Joined: 3/03/2005(UTC) Posts: 287 ![Australia Australia]()
When you mean sequencial your refering to 2x 4 lots of injectors rather than 1x all 8 injectors?
quote: Originally posted by crowe
When you mean sequencial your refering to 2x 4 lots of injectors rather than 1x all 8 injectEdited by user Monday, 17 December 2007 4:33:11 PM(UTC)
| Reason: Not specified |
Hi Guys.
To my knowledge the one sequential motor that was not fitted to the VS III was the HSV 220 kW 5.7 Stroker.
It appears that Holden quietly introduced the 179 kW sequential motor into VS III production in Nov '98, but the 195 kW HSV/HBD versi |
Hi Guys.
It appears that Holden quietly introduced the 179 kW sequential motor into VS III production in Nov 98, but the 195 kW HSV/HBD versio |
all the ones i've seen must be rare! i've seen four or five now!
all the ones ive seen must be rare! ive seen four or five now!
quote: Originally posted by Dr Terry
Hi Guys.
To my knowledge the one sequential motor that was not fitted to the VS III wa |
aren't the S pack utes V6's?
arent the S pack utes V6s?
oh of course, i was always wondering how you got a V8 ute when there was no SS. why would they set it up like that? does that mean the first SS ute was the VU?
Hi boom
You'll note that I used the words 'regular production'.
There were 2 limited edition runs of SS utes for the VS III in '98 & '99.
But the first regular production SS ute was for the VU series from Dec '00.
Dr Terry |
