Fastlane
Holden Forums
Holden General Discussion
VMxxxxxx - is this a Series III VS or a VT Roller?
the manta is a VT by the way so is the Senator
VM - VT 179kW plus VSIII ute and Statesman 179kW. Also VSIII ute and Statesman with HBD 195kW engine. ##
VN - VT 304 HSV 195kW
VP - VL Walkinshaw and VT 5.7L 220kW HSV (different blocks, common number)
VU - VN to VS 304 (except VSIII ute and Stat
Yep red engine cover on the manta
quote: Originally posted by Campbell
VM - VT 179kW plus VSIII ute and Statesman 179kW. Also VSIII ute and Statesman with HBD 1 |
Byron will give you full numbers tomorrow when i get too work if that helps
REMEMBER THE EXHAUST on the ute and statesman, 1 cat single exhaust. that may account for mecal. and hsv mecal tune may differ. when i bought my 179 KW ute thay told me i could not get the 195 KW. they had run out of them. and they informed me about the
Good thread fellas Thinking of buying vs111 maloo and I want to make sure I get the 195 roller motor.is there an easy way to identify this?
Hi tossle.
Yes, the VN engine prefix would be the best ID. Also the build date would have to be 1999 or 2000.
Dr Terry. |
Fastlane
Holden Forums
