#1 Posted : Wednesday, 19 December 2007 4:40:19 AM(UTC)
Hello folks, i am trying to figure out exactly what i have under the bonnet of my HQ
Block casting number is :3970010
Block Casting Date: K 10
Engine No: V973177P, which i understand is a number Victoria Police used to re number unclaimed stolen eninges
any help would be greatly appreciated. cheers
#2 Posted : Wednesday, 19 December 2007 11:26:58 AM(UTC)
mate you have to check out mortech.com for chev info. massive amount of casting number info.
i found out the motor i got in a 1 tonner originally came from a 62 parisienne.
#3 Posted : Wednesday, 19 December 2007 11:26:58 AM(UTC)
i found out the motor i got in a 1 tonner originally came from a '62 parisienne.
#4 Posted : Wednesday, 19 December 2007 4:18:24 PM(UTC)
010 is probably the most widely used of all casting numbers on SBC blocks. It can be found on a 4" bore 1969 to 1979 350 or on a 1969 302, 2 or 4 bolt in horespower ratings from 145hp to 370hp. But, yours has a cast date of 1/10 or 1/11/70 (cant remember
#5 Posted : Wednesday, 19 December 2007 4:18:24 PM(UTC)
010 is probably the most widely used of all casting numbers on SBC blocks. It can be found on a 4" bore 1969 to 1979 350 or on a 1969 302, 2 or 4 bolt in horespower ratings from 145hp to 370hp. But, yours has a cast date of 1/10 or 1/11/70 (can't remember
#6 Posted : Thursday, 20 December 2007 6:12:24 AM(UTC)
its on the next ledge up from the casting number, but still on the same side as the casting number ie: behind the dizzy
#7 Posted : Thursday, 20 December 2007 6:28:08 AM(UTC)
I have a feeling that all 010 blocks in Holdens were McKinnon engines, and that only type 1 HK 327 and type 1 HT 350 manual were Tonnawanda engines. I think the casting number up near the dizzy means not McKinnon, possibly Tonnawanda, but could also be Fl
adam PERTH Offline
#8 Posted : Friday, 21 December 2007 4:07:27 AM(UTC)
adam PERTH
010 blocks hi Nickel for performance / truck
probably 20% -30% chance its a 4 bolt mains.
A1 Bogan.
Edited by user Friday, 21 December 2007 4:16:30 AM(UTC)  | Reason: Not specified
#9 Posted : Sunday, 27 January 2008 9:43:45 AM(UTC)
my chevy casting book says 3970010 can be a 350 or 302 1969-1979 80% chance its a 4 bolta could be passenger car or truck mostly in corvettes anything from 200hp to 370hp. Also in z/28 camaro late 69
ozchevy Offline
#10 Posted : Sunday, 27 January 2008 2:21:21 PM(UTC)
ozchevy
Its a 327cu" 2 Bolt mains engine, manufactured in St.Catherines, Ontario Canada November 10th 1968
ozchevy Offline
#11 Posted : Sunday, 27 January 2008 2:21:21 PM(UTC)
ozchevy
It's a 327cu" 2 Bolt mains engine, manufactured in St.Catherines, Ontario Canada November 10th 1968
#12 Posted : Sunday, 27 January 2008 7:40:33 PM(UTC)
my pontiac has a import block, its an 010 cast dated 1972 my engine # prefix is TKC , I was told from a local chev mechanic Peter Fields it was a Tonnawannda block , 4 bolt, going by the numbers I gave him he said it s almost 100% chance its a corvette b
#13 Posted : Wednesday, 6 February 2008 2:49:51 PM(UTC)
someone told me my eng is a 70 corvet motor vo629cnn is it
This page was generated in 0.112 seconds.
