Hello folks, i am trying to figure out exactly what i have under the bonnet of my HQ
Block casting number is :3970010 Block Casting Date: K 10 Engine No: V973177P, which i understand is a number Victoria Police used to re number unclaimed stolen eninges
any help would be greatly appreciated. cheers
mate you have to check out mortech.com for chev info. massive amount of casting number info. i found out the motor i got in a 1 tonner originally came from a 62 parisienne.
mate you have to check out mortech.com for chev info. massive amount of casting number info. i found out the motor i got in a 1 tonner originally came from a '62 parisienne.
010 is probably the most widely used of all casting numbers on SBC blocks. It can be found on a 4" bore 1969 to 1979 350 or on a 1969 302, 2 or 4 bolt in horespower ratings from 145hp to 370hp. But, yours has a cast date of 1/10 or 1/11/70 (cant remember |
010 is probably the most widely used of all casting numbers on SBC blocks. It can be found on a 4" bore 1969 to 1979 350 or on a 1969 302, 2 or 4 bolt in horespower ratings from 145hp to 370hp. But, yours has a cast date of 1/10 or 1/11/70 (can't remember |
its on the next ledge up from the casting number, but still on the same side as the casting number ie: behind the dizzy
I have a feeling that all 010 blocks in Holdens were McKinnon engines, and that only type 1 HK 327 and type 1 HT 350 manual were Tonnawanda engines. I think the casting number up near the dizzy means not McKinnon, possibly Tonnawanda, but could also be Fl |
010 blocks hi Nickel for performance / truck probably 20% -30% chance its a 4 bolt mains. A1 Bogan. Edited by user Friday, 21 December 2007 4:16:30 AM(UTC)
| Reason: Not specified |
my chevy casting book says 3970010 can be a 350 or 302 1969-1979 80% chance its a 4 bolta could be passenger car or truck mostly in corvettes anything from 200hp to 370hp. Also in z/28 camaro late 69
Its a 327cu" 2 Bolt mains engine, manufactured in St.Catherines, Ontario Canada November 10th 1968
It's a 327cu" 2 Bolt mains engine, manufactured in St.Catherines, Ontario Canada November 10th 1968
my pontiac has a import block, its an 010 cast dated 1972 my engine # prefix is TKC , I was told from a local chev mechanic Peter Fields it was a Tonnawannda block , 4 bolt, going by the numbers I gave him he said it s almost 100% chance its a corvette b
someone told me my eng is a 70 corvet motor vo629cnn is it
