asellar Offline
#1 Posted : Friday, 21 December 2007 6:48:16 AM(UTC)
asellar
have recently had engine and box out and all back in no worries. goes OK but I think I may have some oil on the clutch.
this is based on my speedo and tacho not showing what they should according to my calculations(based on tyre size, gear and diff ratio etc). it seems to be sowing about 70 where it should be 80 more when under load (hills).
also of concern is oil. I took the front and back of the gearbox off and put some silcone on the gaskets to slow the leaks down. didnt work but now there is a lot of oil around the bellhousing all around the back where it meets the gearbox. also some (it seems) on top of the bellhousing but not coming from the engine.
its hard to see coz the engine (pre cross ford 250) is tucked in a transit van.
wondering if anyone knows how to eliminate some issues before getting in and pulling the box and clutch out.
thought maybe the brether tube (if it has one) could be an issue.
anthony (driver)
derrick (77 transit van)
Paul351xb Offline
#2 Posted : Friday, 21 December 2007 7:09:18 AM(UTC)
Paul351xb
What gearbox are you running? In regards to your speedo being out what profile wheels and tyres are you running and what diff centre? You can get different speedo cables for different diff ratios so you might be running the wrong one.
asellar Offline
#3 Posted : Friday, 21 December 2007 8:34:39 AM(UTC)
asellar
hi again.
I have an ex falcon 4 spd (borg warner) and a 3.5 diff.
the speedo cable is standard transit but the markings on the dial have been adjusted to the new setup. also have larger wheels.
all tghis is factored in. I have an excel sheet I can put
Edited by user Friday, 21 December 2007 8:36:30 AM(UTC)  | Reason: Not specified
anthony (driver)
Paul351xb Offline
#4 Posted : Friday, 21 December 2007 9:31:22 AM(UTC)
Paul351xb
From memory there should be a breather tube somewhere on the borgy. If it's blocked or damaged you will get overpressure and oil spilling everywhere. Why are you reversing hard anyway?
Can't help you with the speedo. Speedos from that era are not k
asellar Offline
#5 Posted : Friday, 21 December 2007 10:35:57 AM(UTC)
asellar
thanks paul.
I'll check more on that when the rain stops.
the reversing thing wasnt meant to imply that I just floor it backwards.
any hoo.
thanks for the input.
merry xmas etc
anthony (driver)
anthony (driver)
