Vintage Caravans Offline
#1 Posted : Tuesday, 25 December 2007 10:44:33 PM(UTC)
Vintage Caravans
Hi Guys,
I have a 79 F100 351 Cleveland, factory manual (4 Speed) but would like to swap it over for an auto (C6) can anyone tell me what I will need for the swap???
Steering Column (with Auto shift)
Pedal Assembly
Flywheel?
Gearbox
Tailshaft
Torque Converter
Will I need to find anything else??
Matt
79 F100 XLT 351, 62 EK 327 Wagon, 62 EK 327 Ute 62 EK 307 Van 90 VN 304 Berlina -
Hmmm I see a pattern forming!!
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
#2 Posted : Wednesday, 26 December 2007 1:40:14 AM(UTC)
Has your radiator got a tranny cooler in it? Don't forget your tranny cooler lines, your ring gear bolts are usually shorter than your flywheel bolts ( as its thinner). Also, don't forget to remove the spigot bearing in the back of the crankshaft. Merry X
basketcasebear Offline
#3 Posted : Wednesday, 26 December 2007 4:26:59 AM(UTC)
basketcasebear
hey vintage holden,
I know a bloke here in mathoura, who has a complete f100 83model, and he remodeled a tree with it,,but it is still mostly ok, motor auto diff etc?
let me know if you want to know more?
ptpro
madmax transit, 308t400 camper
DOH!!!
#4 Posted : Wednesday, 26 December 2007 7:01:03 PM(UTC)
Vintage Caravans
Email sent
Matt
swanny Offline
#5 Posted : Wednesday, 26 December 2007 9:22:51 PM(UTC)
swanny
if u run through oil cooler u wont need to change radiator if it hasn't got fittings for auto . they can sometimes heat up oil to much running through radiator but if it does run through cooler as well
#6 Posted : Thursday, 27 December 2007 12:05:24 AM(UTC)
Vintage Caravans
Thanks Swanny, I was hoping to run a trans oil cooler and not have to swap the original radiator that I have just had rebuilt! so thanks for the info
Matt
Hmmm I see a
