coley13 Offline
#1 Posted : Thursday, 27 December 2007 5:21:21 PM(UTC)
coley13
my brother found me a 4 speed, complete conversion from flywheel to pedals etc. the thing that through me off was he said it was an m22. i was under the impression an m22 was a 6 cylinder gearbox, he said it was a factory 1 tonner gearbox behind a 253. can anyone tell me the input shaft length so my brother doesnt get me a 6 cylinder gearbox by mistake.
i dont really care if it's an m20 or m21 just want to make sure i dont get a 6 cylinder one. as i cant see this gearbox i need to tell my brother to measure input shaft length for me.
crowe Offline
#2 Posted : Thursday, 27 December 2007 10:01:52 PM(UTC)
crowe
Holden didn't make a V8 M22. although you can make one up using a V8 3speed shaft into a 6cyl M22. This box is not strong as the input shaft has fewer teeth meshing to the side counter gear. A bit like putting a smaller tooth front cog on a motot bike to
crowe Offline
#3 Posted : Thursday, 27 December 2007 10:01:52 PM(UTC)
crowe
Holden didnt make a V8 M22. although you can make one up using a V8 3speed shaft into a 6cyl M22. This box is not strong as the input shaft has fewer teeth meshing to the side counter gear. A bit like putting a smaller tooth front cog on a motot bike to c
wombat1 Offline
#4 Posted : Friday, 28 December 2007 1:12:17 PM(UTC)
wombat1
m22 gearbox had a very low first gear 3.74:1 ratio , being that low it is most likly out of a 1 tonner more like a 6 than a 8 thou , but not dead sure on that..,..
wombat
coley13 Offline
#5 Posted : Friday, 28 December 2007 4:49:27 PM(UTC)
coley13
input shaft lentgh for the v8 is what i need to know? im not fussed on whether its a m20, m21 ,m22. i just dont want to end up with a 6 cylider box
coley13 Offline
#6 Posted : Friday, 28 December 2007 4:49:27 PM(UTC)
coley13
input shaft lentgh for the v8 is what i need to know? i'm not fussed on whether it's a m20, m21 ,m22. i just dont want to end up with a 6 cylider box
#7 Posted : Friday, 28 December 2007 6:15:40 PM(UTC)
Corey13.If you look here http://gallery.oldholden...pd/P6230013_001.jpg.html I have a pic that gives you a measurement and shows the difference between the two input shafts and retainers.
Paul.
coley13 Offline
#8 Posted : Saturday, 29 December 2007 12:31:30 AM(UTC)
coley13
cheers paul, thats what i was after
#9 Posted : Sunday, 30 December 2007 4:19:38 AM(UTC)
If you are buying the whole conversion also be careful that its from the same model as yours eg if yours is a HQ you really want HQ etc. Differences in pedal setups, clutch mechanisms etc are a pain in the proverbial. The M22 is the best box to get in my
#10 Posted : Sunday, 30 December 2007 4:19:38 AM(UTC)
If you are buying the whole conversion also be careful that it's from the same model as yours eg if yours is a HQ you really want HQ etc. Differences in pedal setups, clutch mechanisms etc are a pain in the proverbial. The M22 is the best box to get in my
