hz dude Offline
#1 Posted : Friday, 28 December 2007 7:24:56 PM(UTC)
hz dude
A mates got a VB v8 he wants to fit the elec dash from a VK calais
The main problem that I can see is that theres no speedo cable like on his old dash
how can we get around this ? the car that had the dash was a trimatic and his is a th400
can the wiring loom from the trimatic be used on the th400 ?
can this be done ?
thanx dudes and have a happy new year
it's beer o'clock
#2 Posted : Friday, 28 December 2007 8:33:59 PM(UTC)
The VK speed sensor is mounted to the cruise control unit - which sits below the brake booster.
The other side of the cruise control unit is driven via a short speedo cable to the gearbox.
According to the parts manual, a VB TH400 speedo cable is the
#3 Posted : Friday, 28 December 2007 8:44:04 PM(UTC)
^^probably need to keep going!
That will sort out the actual speed sender, but the dash itself needs lots more work.
The VK body & dash harness is very different to a VB, and you cant plug & play bits & pieces of it - your only plug & play solution
#4 Posted : Friday, 28 December 2007 8:44:04 PM(UTC)
The VK body & dash harness is very different to a VB, and you can't 'plug & play' bits & pieces of it - your only plug & play soluti
hz dude Offline
#5 Posted : Friday, 28 December 2007 9:03:57 PM(UTC)
hz dude
wrecking a VK calais so I have all the parts here but sounds like a pain in the ar$e
will try to talk him out of it . but if he wont listen he has all the info to do it
thanx dude for all your help happy new year.
it's beer o'clock
hz dude Offline
#6 Posted : Friday, 28 December 2007 9:03:57 PM(UTC)
hz dude
its beer oclock
#7 Posted : Friday, 28 December 2007 11:50:59 PM(UTC)
If he has the entire VK there, then I would suggest he do a total loom swapover with everything.
So if you cant talk him out of it, at least make him do a total loom swap.
The hardest parts will be making a mount for the fuse box, and drilling the 6
#8 Posted : Friday, 28 December 2007 11:50:59 PM(UTC)
So if you can't talk him out of it, at least make him do a total loom swap.
boom Offline
#9 Posted : Sunday, 30 December 2007 1:20:33 AM(UTC)
boom
mate, your lucky if the electronic dash still works!!
boom Offline
#10 Posted : Sunday, 30 December 2007 1:20:33 AM(UTC)
boom
hz dude Offline
#11 Posted : Monday, 31 December 2007 1:04:37 AM(UTC)
hz dude
works well doesnt fliker best elecy dash i'v ever seen its a gem
ever thing works all functions
it's beer o'clock
hz dude Offline
#12 Posted : Monday, 31 December 2007 1:04:37 AM(UTC)
hz dude
works well doesnt fliker best elecy dash iv ever seen its a gem
its beer oclock
