keithholden Offline
#1 Posted : Saturday, 29 December 2007 10:00:27 PM(UTC)
keithholden
I went to certify my car and only 6 things to fix.
One was that the speedo is reading incorrect. It says im going faster than I am. Is this an easy fix??
I have a sailsbury diff from a chev statesman with 14 inch wheels the tyres are 265/50/14 inch.
Im almost done on the other things so not far to go now :)
#2 Posted : Sunday, 30 December 2007 1:39:22 AM(UTC)
Check out your diff ratio which should be stamped on the round metal plate just behind the diff yoke.
Post the diff ratio on this forum.
I have several different colour transmission speedo drive gears to suit TH400, will see if we can find one to su
wildshotz Offline
#3 Posted : Monday, 31 December 2007 5:51:53 AM(UTC)
wildshotz
Hi Luke.
Sorry to hijack this thread but do you have a speedo gear to suit t400 and 3.08 diff with 15 inch wheels?
Dave
email [email protected]
Edited by user Monday, 31 December 2007 5:53:26 AM(UTC)  | Reason: Not specified
keithholden Offline
#4 Posted : Monday, 31 December 2007 6:58:44 AM(UTC)
keithholden
Hi ratio is 2.78 luke
#5 Posted : Monday, 31 December 2007 7:06:20 PM(UTC)
Originally posted by wildshotz
Hi Luke.
#6 Posted : Tuesday, 1 January 2008 7:44:26 AM(UTC)
Hi Guys,
You will need to find a light green speedo driven gear for you TH400. Light green has 34 teeth. Or a pink with 35 teeth should be pretty close for both of you. I only have a dark green left with 42 teeth to suit a 3.36 diff. I thought i had m
trev10 Offline
#7 Posted : Tuesday, 1 January 2008 8:12:09 PM(UTC)
trev10
Guys,
I recently purchased a T400 from Chevpower in Perth for my HQ rebuild and noticed the two gears are 11t & 43t for the speedo drive. I have read elsewhere about the first gear should be 8t or 9t in most cases. Can you shed any light on this. How
keithholden Offline
#8 Posted : Sunday, 6 January 2008 10:41:11 AM(UTC)
keithholden
I have a yellow one in the garage.Ill have to count the teeth. I think its from a th400 but as ive never had one apart I couldnt say for sure.
Are they easy to remove??
I have to do it next week when the parts place goes back to work so I can get what
keithholden Offline
#9 Posted : Tuesday, 8 January 2008 6:04:10 PM(UTC)
keithholden
Byron I rang about sle one and theres 2 choices one is 40teeth and the other is 35. As they couldnt tell me the tyre size of the car ( or to lazy lol) They didnt have any on the books any longer so put me on to Rarespares which didnt have any new ones in
Tour Director Offline
#10 Posted : Tuesday, 8 January 2008 6:31:49 PM(UTC)
Tour Director
You could try Rare Spares as they have a comprehensive range of new speedo gears
#11 Posted : Tuesday, 8 January 2008 10:16:41 PM(UTC)
keithholden Offline
#12 Posted : Thursday, 10 January 2008 7:09:59 PM(UTC)
keithholden
I decided to remove my one before I went to look for a replacement and it was 35 teeth. So that made me go for the 40 which was also for a sle v8.
Like Byron said on the housing is a bunch of numbers eg 35 36 37 38 39 which represents which ones go int
This page was generated in 0.066 seconds.
