Fastlane
Holden Forums
Holden General Discussion
Th400 now speedo is about 20% to fast. was 202
I went to certify my car and only 6 things to fix. One was that the speedo is reading incorrect. It says im going faster than I am. Is this an easy fix?? I have a sailsbury diff from a chev statesman with 14 inch wheels the tyres are 265/50/14 inch.
Im almost done on the other things so not far to go now :)
If its not broke it will be soon |
Check out your diff ratio which should be stamped on the round metal plate just behind the diff yoke.
Post the diff ratio on this forum.
I have several different colour transmission speedo drive gears to suit TH400, will see if we can find one to su
Hi Luke. Sorry to hijack this thread but do you have a speedo gear to suit t400 and 3.08 diff with 15 inch wheels? Dave email [email protected]Edited by user Monday, 31 December 2007 5:53:26 AM(UTC)
| Reason: Not specified
Hi ratio is 2.78 luke
quote: Originally posted by wildshotz
Hi Luke. Sorry to hijack this thread but do you have a speedo gear to suit t400 and 3.0 |
Hi Guys,
You will need to find a light green speedo driven gear for you TH400. Light green has 34 teeth. Or a pink with 35 teeth should be pretty close for both of you. I only have a dark green left with 42 teeth to suit a 3.36 diff. I thought i had m
Guys, I recently purchased a T400 from Chevpower in Perth for my HQ rebuild and noticed the two gears are 11t & 43t for the speedo drive. I have read elsewhere about the first gear should be 8t or 9t in most cases. Can you shed any light on this. How
I have a yellow one in the garage.Ill have to count the teeth. I think its from a th400 but as ive never had one apart I couldnt say for sure.
Are they easy to remove?? I have to do it next week when the parts place goes back to work so I can get what |
Byron I rang about sle one and theres 2 choices one is 40teeth and the other is 35. As they couldnt tell me the tyre size of the car ( or to lazy lol) They didnt have any on the books any longer so put me on to Rarespares which didnt have any new ones in |
Joined: 2/03/2005(UTC) Posts: 451  ![Australia Australia]() Was thanked: 15 time(s) in 14 post(s)
You could try Rare Spares as they have a comprehensive range of new speedo gears
quote: Originally posted by keithholden
Byron I rang about sle one and theres 2 choices one is 40teeth and the other is 35. As |
I decided to remove my one before I went to look for a replacement and it was 35 teeth. So that made me go for the 40 which was also for a sle v8.
Like Byron said on the housing is a bunch of numbers eg 35 36 37 38 39 which represents which ones go int |
Fastlane
Holden Forums
