keithholden Offline
#1 Posted : Saturday, 29 December 2007 11:19:22 PM(UTC)
keithholden
Looks to be just past 2 and 3/4 turns when I jacked the car and turned both wheels at the same time and counted the turns of the driver shaft.
What would the closest holden ratio be??
Cheers.
I need this apparantly for speedo recalibration
Bluez Offline
#2 Posted : Sunday, 30 December 2007 12:28:07 AM(UTC)
Bluez
might be 2.78
i think the ratio is stamped on the round metal plate just back from the diff yoke. i might be thinking of banjo diff. but its worth a look. might need a bit of a clean to see it.
Jesse Jesse Jesse, you've not got a sense of humour!
keithholden Offline
#3 Posted : Sunday, 30 December 2007 12:54:39 AM(UTC)
keithholden
Sweet ill check tomorrow. If its not there ill go with 2.78 cheers
bundybluedog Offline
#4 Posted : Sunday, 30 December 2007 2:02:05 AM(UTC)
bundybluedog
It should also be stamped on the crown wheel if you look behind the rear cover. it will be 2.78 the next one up is 3.08. i bought a diff that said 3.55 on the dust cover behind the yoke and is was still siting on 1800rpm down the highway intead of about 3
