Fastlane
Holden Forums
Holden General Discussion
Diff ratio Sailsbury looks just over 2.75 what wo
Thanks Given:
Looks to be just past 2 and 3/4 turns when I jacked the car and turned both wheels at the same time and counted the turns of the driver shaft.
What would the closest holden ratio be?? Cheers. I need this apparantly for speedo recalibration
If its not broke it will be soon |
Joined: 1/03/2005(UTC) Posts: 241  ![Australia Australia]() Thanks: 3 times
might be 2.78 i think the ratio is stamped on the round metal plate just back from the diff yoke. i might be thinking of banjo diff. but its worth a look. might need a bit of a clean to see it. |
Jesse Jesse Jesse, you've not got a sense of humour! |
Thanks Given:
Sweet ill check tomorrow. If its not there ill go with 2.78 cheers
It should also be stamped on the crown wheel if you look behind the rear cover. it will be 2.78 the next one up is 3.08. i bought a diff that said 3.55 on the dust cover behind the yoke and is was still siting on 1800rpm down the highway intead of about 3 |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
Fastlane
Holden Forums
