basketcasebear Offline
#1 Posted : Sunday, 30 December 2007 4:05:24 AM(UTC)
basketcasebear
This is the case of the diff that turns less than it should??
I got under 3.35 diff, stamped]and turned shaft, to count how many turns the wheels do??
the tail shaft turns 2 turns,,and the wheel turns just under 2 turns??
this does not seem correctamundo to me!!!!
I have done it 3 times!!!
or has this bear finally fallen out of his tree??[probably]
ptpro
madmax transit, 308t400 campervan
DOH!!!
VL05 Offline
#2 Posted : Sunday, 30 December 2007 5:30:45 AM(UTC)
VL05
I have experienced the same thing, I have a 3.36 ratio diff, I spin the tailshaft once and the wheel turns just under 2 turns as well.
WANTED: GTS rims, seats and mirrors to suit HJ.
#3 Posted : Sunday, 30 December 2007 5:48:11 AM(UTC)
basketcasebear
so I wonder how come??
ptpro
DOH!!!
JBM Offline
#4 Posted : Sunday, 30 December 2007 5:50:08 AM(UTC)
JBM
Turn the driveshaft more times and you may see more of a difference, put chalk marks on the yoke and the tire and get someone else to count with you. Are both wheels off the ground, is it a limited slip centre or open?
James
#5 Posted : Sunday, 30 December 2007 6:05:22 AM(UTC)
basketcasebear
hey JBM,
It is not a LS diff, and both wheels are off the ground, and the shaft has a round bump in the middle, so not hard to see a turn, and the wheels have name tags on them,, there is no mistake in the revolutions?
Gee at that ratio,,i will be doing
DOH!!!
bundybluedog Offline
#6 Posted : Sunday, 30 December 2007 8:46:57 AM(UTC)
bundybluedog
take it to the salt lakes when your finished set a land speed record
81837 Offline
#7 Posted : Sunday, 30 December 2007 7:21:55 PM(UTC)
81837
It sounds like only one wheel is turning, in which case it will turn twice as far. With both wheels turning, one rev of the tailshaft will give about 1/3 rev of the wheels, with only one wheel turning, one rev of the tailshaft will give 2/3 rev of the whe
classic oz wreck Offline
#8 Posted : Sunday, 30 December 2007 9:53:38 PM(UTC)
classic oz wreck
when you say the diff is stamped,do you mean on the dust seal at the yoke?...or on the crown wheel itself?...if your working on the dust seal..DONT...drop the hat for the correct ration stamped on the crown wheel...i have seen literally hundreds of diffs
www.classicozwreck.com.au
#9 Posted : Sunday, 30 December 2007 10:58:50 PM(UTC)
basketcasebear
Hey classic oz wreck,
it has a sticker on the axle,, so I think it is this ratio, came out of a front smashed AU tonner, under 200k,s on clock,
sounds like 81837 is correctomundo,
hope and pray???
ptpro
DOH!!!
