5 Pages<1234>»
byjingo Offline
#21 Posted : Monday, 31 December 2007 9:44:25 PM(UTC)
byjingo
Mark....the Ron Dickson HQ was at the Muscle Car Masters in Sydney recently....pic in the latest AMC mag. Also how many XW8 manuals have you on your register?....I know of 8.
Regards Matt
byjingo Offline
#22 Posted : Monday, 31 December 2007 9:44:25 PM(UTC)
byjingo
Regards Matt
monaro mark Offline
#23 Posted : Tuesday, 1 January 2008 9:24:04 PM(UTC)
monaro mark
Oh ok cool, I haven't bought the latest one yet. I haven't added any cars yet but I know of 4 manuals. When I have have it up and running I'll let you know and would you be able to pass along the url to the owners if you know them?
My Monaros:
monaro mark Offline
#24 Posted : Tuesday, 1 January 2008 9:24:04 PM(UTC)
monaro mark
Oh ok cool, I havent bought the latest one yet. I havent added any cars yet but I know of 4 manuals. When I have have it up and running Ill let you know and would you be able to pass along the url to the owners if you know them?
My Monaros:
- HQ GTS 4 Monaro 350, Auto, Mustard, Black Trim
- HQ GTS 4 Monaro 308, Manual, Orchid Metallic, Black Trim
adam PERTH Offline
#25 Posted : Tuesday, 1 January 2008 10:46:23 PM(UTC)
adam PERTH
were those L30 engines 3970010 casting?
or a mixture of other castings?
A1 Bogan.
adam PERTH Offline
#26 Posted : Tuesday, 1 January 2008 10:46:23 PM(UTC)
adam PERTH
A1 Bogan.
#27 Posted : Tuesday, 1 January 2008 10:51:43 PM(UTC)
All HQ L30 were.
#28 Posted : Tuesday, 1 January 2008 10:51:43 PM(UTC)
All HQ L30 were.
clearway Offline
#29 Posted : Wednesday, 2 January 2008 11:40:32 AM(UTC)
clearway
Going from conversations with mates, date codes, engine,gearbox, carb etc it has been said they are in the year of 71 , would this be the same fo intake and exhuast maifold would the L30 engine be date coded 71 for the GTS4 ???? although they had a short run from 3/73 to 8/73 lets say a six months run . Byron Rich quoted that the date format would be MDY usa , was the engine for the GTS4 350 an imported us engine ???? who knows JBM quoted that they were not imported engines , anyone !!!!!! Byjingo what does your have mate ,
is it in that range ,or am i way off with my infor above, the other 4 manual cars that Mark knows off, should all marry up . has any of these GTS4 been judged at natoinals ? are the GTS4 autos any different in date codes as per year or in the 71 range ?????
" Smokem Baby "
" Smokem Baby "
clearway Offline
#30 Posted : Wednesday, 2 January 2008 11:40:32 AM(UTC)
clearway
" Smokem Baby "
#31 Posted : Wednesday, 2 January 2008 4:58:57 PM(UTC)
Th engines used in HQ 350s, Statesman, Monaaro GTS 350 and Monaro LS, plus a couple of "specials" are all the same, manual and auto.
I doubt a 71 engine would be in stoclk in 73 when they made the first GTS 4 doors. Not sure about you date for the last
#32 Posted : Wednesday, 2 January 2008 4:58:57 PM(UTC)
I doubt a 71 engine would be in stoclk in 73 when they made the first GTS 4 doors. Not sure about you date for the last one though, I think they still made them in 74. (they used thousands of 350s in the HQ, most in Statesmans, only a few hundred in Monaros)
If you have the full engine number we cantry and find what type of car it came out of and when.
All the 350s were imported but they were then iven an Australian engine number, this is the critical number and probably what JBM meant.
Warren
byjingo Offline
#33 Posted : Wednesday, 2 January 2008 8:56:42 PM(UTC)
byjingo
The manual examples I know of are original and date coded 1971 engines, one of these is a late production Melbourne vehicle and still has a 71 engine. I am guessing....but as manual 350 vehicles were much lower production than autos it took longer to use up the stock of engines....therefore they were older when fitted. So I would say that manifolds, carby, water pump, starter motor and gearbox should be date coded 71 if it was/is an original example, it was all assembled with the engine in Canada(McKinnon plant) in 1971.
If you are trying to match up your engine date code to see if it fits in sequence with others you really need to find an original example from the same VAP as your own, and compare numbers and date codes. Not an easy task.
Matt
byjingo Offline
#34 Posted : Wednesday, 2 January 2008 8:56:42 PM(UTC)
byjingo
The manual examples I know of are original and date coded 1971 engines, one of these is a late production Melbourne vehicle and still has a 71 engine. I am guessing....but as manual 350 vehicles were much lower production than auto's it took longer to use
#35 Posted : Thursday, 3 January 2008 5:29:38 AM(UTC)
There is no difference in a maual and auto engine, so that theory is flawed. It was different in the HT and HG but not HQ.
Warren
#36 Posted : Thursday, 3 January 2008 5:29:38 AM(UTC)
Warren
clearway Offline
#37 Posted : Thursday, 3 January 2008 6:01:26 AM(UTC)
clearway
3970010 casting number for the L30 egine
The casting numbers tells you alot, the 010 at the end means it is a Chevy 350, the 70 means it is out of a 70s model vehicle and the 39 means (if I remember correctly ) that it is from a 71 350 vehicle??.
the gerabox in the 4 speed 350 gts4 were not m22 they were m20 dated 71 like the engine a all other parts intake exhuast etc
i have seen markings L240 on the GTS4 , but do not know what it means , anyone know ???? and seen on other toranas L340 , am i wrong by saying the gts4 was a L24 and the toranas were a L34 ?????
" Smokem Baby "
" Smokem Baby "
clearway Offline
#38 Posted : Thursday, 3 January 2008 6:01:26 AM(UTC)
clearway
The casting numbers tells you alot, the 010 at the end means it is a Chevy 350, the 70 means it is out of a 70's model vehicle and the 39 means (if I remember correctly ) that it is from a 71 350 vehicle??.
the
" Smokem Baby "
clearway Offline
#39 Posted : Thursday, 3 January 2008 6:08:59 AM(UTC)
clearway
can someone explain to me where the XW8 derives from ,as i have read it in posts and do not know what it means
" Smokem Baby "
Edited by user Thursday, 3 January 2008 6:10:00 AM(UTC)  | Reason: Not specified
" Smokem Baby "
clearway Offline
#40 Posted : Thursday, 3 January 2008 6:08:59 AM(UTC)
clearway
" Smokem Baby "
" Smokem Baby "
5 Pages<1234>»
