Rhys Offline
#1 Posted : Tuesday, 8 January 2008 4:40:38 AM(UTC)
Rhys
Hi All,
Does anyone know if the power steering ratio in the whole WB series was 16.7:1 or was 20:1 also a WB ratio? What had what?
If I was to replace a power steering box would it be easy enough getting both types of ratios?
thanks
Rhys
#2 Posted : Wednesday, 9 January 2008 3:19:39 AM(UTC)
hi Rhys
hmmm ... this info comes from the Unique Cars and Parts website ...
http://www.uniquecarsand...nical_specifications.htm
Im not sure whether theyve missed a bit after the Statesman specs or not ...
Standard: Front-mou
#3 Posted : Wednesday, 9 January 2008 3:19:39 AM(UTC)
hi Rhys
I'm not sure whether they've missed a bit after the Statesman specs or not ...
Standard: Front-m
HZute-efi-VS5L Offline
#4 Posted : Wednesday, 9 January 2008 4:53:30 AM(UTC)
HZute-efi-VS5L
how do you id the diferent ratios? is there stampings that are shown on the boxes?
jason
www.stickthisdecals.com.au
#5 Posted : Wednesday, 9 January 2008 6:14:10 PM(UTC)
Hi Guys.
Quote:
"Standard: Front-mounted recirculating ball type. Standard ratio 25:1
Optional power assisted: Integral variable ratio gear with rotary type control valve and hydraulic pump. Ratio varies from 18:1 to 11.7:1
Statesman: Integral
#6 Posted : Wednesday, 9 January 2008 9:16:37 PM(UTC)
hi Dr Terry
how did they manage to get the extra 'feel' into the power steering of the RTS Holdens? Was it to do with the length of the steering arms, or some other trick? TheHZs/WBs certainly seem to have more weighting and feel than the previous models
#7 Posted : Wednesday, 9 January 2008 9:16:37 PM(UTC)
hi Dr Terry
how did they manage to get the extra feel into the power steering of the RTS Holdens? Was it to do with the length of the steering arms, or some other trick? TheHZs/WBs certainly seem to have more weighting and feel than the previous models,
#8 Posted : Wednesday, 9 January 2008 11:00:30 PM(UTC)
Hi Frank
There were several modifications that made them feel better, but most of it was the RTS suspension.
The torsion rod & the spool valve in the box were altered for better feel in the HZ/WB, but that alone doesnt make a huge difference. If you
#9 Posted : Wednesday, 9 January 2008 11:00:30 PM(UTC)
Hi Frank
The torsion rod & the spool valve in the box were altered for better feel in the HZ/WB, but that alone doesn't make a huge difference. If yo
Rhys Offline
#10 Posted : Sunday, 13 January 2008 4:59:24 AM(UTC)
Rhys
Thanks a lot for all of the information Dr Terry. At least now I know when I go and get a new power steering box it will be the correct/same ratio.
Rhys
Guest (5)
