ozchevy Offline
#1 Posted : Tuesday, 8 January 2008 6:38:39 AM(UTC)
ozchevy
Hi guys,
Can someone tell me if an HJ-HZ V8 brake booster will fit a HQ V8 with Girlock master cylinder and Girlock front calipers with drums on rear. I've heard only the HQ booster will go back and no others is suitable. Is this correct?
#2 Posted : Tuesday, 8 January 2008 7:00:38 AM(UTC)
AFAIK all boosters are the same wrt 6cyl or V8, except HZ disc/disc type. I think the only difference is bent or straight pushrod, depending upon the brake pedal. If you are stuck change pedals. I'm sure if i'm wrong someone will confirm.
_____________
#3 Posted : Tuesday, 8 January 2008 7:00:38 AM(UTC)
AFAIK all boosters are the same wrt 6cyl or V8, except HZ disc/disc type. I think the only difference is bent or straight pushrod, depending upon the brake pedal. If you are stuck change pedals. Im sure if im wrong someone will confirm.
_______________
ozchevy Offline
#4 Posted : Tuesday, 8 January 2008 9:09:31 AM(UTC)
ozchevy
Thanks for that Byron.
#5 Posted : Tuesday, 8 January 2008 12:05:03 PM(UTC)
HQ has the bent pushrod and the later ones wont fit properly. dont know if you can change pedals. 6 and 8 boosters are the same except the disk/disk ones which are dual diaphragm.
#6 Posted : Tuesday, 8 January 2008 12:05:03 PM(UTC)
HQ has the bent pushrod and the later ones won't fit properly. don't know if you can change pedals. 6 and 8 boosters are the same except the disk/disk ones which are dual diaphragm.
ozchevy Offline
#7 Posted : Tuesday, 8 January 2008 3:19:39 PM(UTC)
ozchevy
Ok,
John - that been the case, re: (bent pushrod) is it possible to bend the rod from a unit out of an HJ Booster, or is the rod a completely different length?
Reason I'm asking is I know a guy with a recond booster who is asking only $40.00 complete w
ozchevy Offline
#8 Posted : Tuesday, 8 January 2008 3:19:39 PM(UTC)
ozchevy
Ok,
Reason Im asking is I know a guy with a recond booster who is asking only $40.00 complete wi
#9 Posted : Tuesday, 8 January 2008 4:18:53 PM(UTC)
The end of the pushrod is a flat tab, so it won't bend very easily. Just use a HJ pedal. It will bolt straight in. From memory the only difference is the location of the hole for the pin that attaches it to the brake booster pushrod. The only thing about
#10 Posted : Tuesday, 8 January 2008 4:18:53 PM(UTC)
The end of the pushrod is a flat tab, so it wont bend very easily. Just use a HJ pedal. It will bolt straight in. From memory the only difference is the location of the hole for the pin that attaches it to the brake booster pushrod. The only thing about t
HZute-efi-VS5L Offline
#11 Posted : Tuesday, 8 January 2008 5:11:27 PM(UTC)
HZute-efi-VS5L
correct. if you have a hq and want to fit a hj-hz booster change the peddle also. a 4wdisc hz booster will also fit no worries but isnt nessasary without disc rear.
if you want a z peddle let me know i have one here is only a auto one but if you need
www.stickthisdecals.com.au
#12 Posted : Tuesday, 8 January 2008 10:18:21 PM(UTC)
Id use a manual pedal anyway even on an auto. It makes it easier to get your feet into the car especially with steel capped boots on.
If we all had the same (good) taste, who would buy all the Fo
#13 Posted : Tuesday, 8 January 2008 10:18:21 PM(UTC)
I'd use a manual pedal anyway even on an auto. It makes it easier to get your feet into the car especially with steel capped boots on.
#14 Posted : Wednesday, 9 January 2008 4:54:01 AM(UTC)
HZute-efi-VS5L
yes good point....
classic oz wreck Offline
#15 Posted : Wednesday, 9 January 2008 7:24:08 AM(UTC)
classic oz wreck
your all wrong....hq and hj are the same straight rod out of the booster and hx hz wb are the ones with the bent rod
www.classicozwreck.com.au
#16 Posted : Wednesday, 9 January 2008 7:44:18 AM(UTC)
HZute-efi-VS5L
wb is diferent also yeh? wb auto brake peddle is diferent to hz from what i have found.
#17 Posted : Wednesday, 9 January 2008 8:34:27 AM(UTC)
classic oz wreck
only in looks if its from a statesman...fit wise its the same as hx hz..
#18 Posted : Wednesday, 9 January 2008 6:15:00 PM(UTC)
HZute-efi-VS5L
ah har there ya go....
#19 Posted : Friday, 11 January 2008 11:29:20 PM(UTC)
hey got a 186 hk lookin at puttin in a 307 worked motor, changed brakes to HQ discs at front , just wondering what type of booster an master cylinder i need can i use the same 1 or will i need a set from a V8 hk/t/g
#20 Posted : Friday, 11 January 2008 11:29:35 PM(UTC)
Guest (11)
This page was generated in 0.082 seconds.
