#1 Posted : Wednesday, 9 January 2008 3:43:31 AM(UTC)
HOW CAN I TELL THE DIFFERENCE BETWEEN AN M21 AND M20 GEARBOX? I HAVE A 4 SPD BOX IN FRONT OF ME HOW CAN I TELL WHAT IT IS?
#2 Posted : Wednesday, 9 January 2008 5:19:15 AM(UTC)
There should be a groove machined into the front of the input shaft - where the splines start.
From memory, 1 groove is M20, 2 grooves is M21.
A lot of people aim to a
#3 Posted : Wednesday, 9 January 2008 5:34:56 AM(UTC)
Not always. Put it in 1st gear, and turn the input shaft so that the output shaft turns once. Count how many times you turn the input shaft. 3.74 = M22. 3.05=M20. 2.54 (V8) =M21. 2.54(6cyl) = XU-1 M20 or M21. If it's any other ratio post back here and i'l
#4 Posted : Wednesday, 9 January 2008 5:34:56 AM(UTC)
Not always. Put it in 1st gear, and turn the input shaft so that the output shaft turns once. Count how many times you turn the input shaft. 3.74 = M22. 3.05=M20. 2.54 (V8) =M21. 2.54(6cyl) = XU-1 M20 or M21. If its any other ratio post back here and ill
Snotty Nosed Vulture Offline
#5 Posted : Wednesday, 9 January 2008 9:35:43 AM(UTC)
i have always worked on:
no groove = M22
1 groove = M20
2 grooves = M21
exceptions to this rule are rare.
"I can circle for days"
#6 Posted : Wednesday, 9 January 2008 10:13:31 PM(UTC)
Exceptions to it are common im my experience. Especially with the proliferation of aftermarket input shafts. Plus XU-1 box with 899 cluster has 2 grooves, and it's not an M21 (or an M20 for that matter). Same for L34 track pack box.
___________________
#7 Posted : Wednesday, 9 January 2008 10:13:31 PM(UTC)
Exceptions to it are common im my experience. Especially with the proliferation of aftermarket input shafts. Plus XU-1 box with 899 cluster has 2 grooves, and its not an M21 (or an M20 for that matter). Same for L34 track pack box.
____________________
#8 Posted : Thursday, 10 January 2008 5:20:44 AM(UTC)
I WAS TOLD THE V8 M21 G/BOX HAD A LONGER INPUT SHAFT. IS THIS CORRECT?
#9 Posted : Thursday, 10 January 2008 6:04:52 AM(UTC)
All V8 aussie 4spd boxes have a longer input shaft, including the V8 3spd.
