Can anyone tell me if a g/box crossmember from a Turbo 350 trans HT would be suitable for a HT with an EFI 304 and T700. Cheers.
No. You'll be close with a trimatic one. Try CRS - they may make one to suit. I think you'll have to do floor surgery to fit the TH700 thought.
_______________________________________________________ If we all had the same (good) taste, who would buy |
No. Youll be close with a trimatic one. Try CRS - they may make one to suit. I think youll have to do floor surgery to fit the TH700 thought.
_______________________________________________________ If we all had the same (good) taste, who would buy al |
Hi Byron.
The TH700 rear mount sit at the same height, but slightly further back as V8 Powerglide & Saginaw. An HT V8 Powerglide crossmember would be my choice. |
Hi again.
I didn't read the question properly. There is no such thing as a genuine HT TH350 crossmember, it's probably just a V8 Powerglide anyway. TH350 has the same rear mount position as the V8 Powerglide & Saginaw.
So, yes it should fit the TH70 |
Hi again.
I didnt read the question properly. There is no such thing as a genuine HT TH350 crossmember, its probably just a V8 Powerglide anyway. TH350 has the same rear mount position as the V8 Powerglide & Saginaw.
So, yes it should fit the TH700, |
