hgkid1 Offline
#1 Posted : Friday, 11 January 2008 2:40:23 AM(UTC)
hgkid1
how hard is it to go from red 202 to black 3.3 power? is it just bolt in and run wires or is there major work involved?
peter_flane Offline
#2 Posted : Friday, 11 January 2008 5:35:14 AM(UTC)
peter_flane
Not hard. No major work other than exhaust. If you don't have the exhaust for the black, you need some 12 port extractors
peter_flane Offline
#3 Posted : Friday, 11 January 2008 5:35:14 AM(UTC)
peter_flane
Not hard. No major work other than exhaust. If you dont have the exhaust for the black, you need some 12 port extractors
hgkid1 Offline
#4 Posted : Friday, 11 January 2008 8:16:41 PM(UTC)
hgkid1
Excellent. so could i just plug all the wiring loom into the same plug that the red motor plugged into? and connect the right bolts and exhaust etc and start her up? is it that easy?
#5 Posted : Friday, 11 January 2008 8:53:25 PM(UTC)
Hi hgkid1.
You haven't actually said what car this is going into, but I will assume from your name, it's an HG.
If you're going to put a Black carby motor into an HG, use the HG engine's harness. It's only about 5 wires or so, anyway.
This job is
#6 Posted : Friday, 11 January 2008 8:53:25 PM(UTC)
Hi hgkid1.
You havent actually said what car this is going into, but I will assume from your name, its an HG.
If youre going to put a Black carby motor into an HG, use the HG engines harness. Its only about 5 wires or so, anyway.
This job is not
#7 Posted : Friday, 11 January 2008 10:24:41 PM(UTC)
Was thanked: 612 time(s) in 579 post(s)
And youll need to bypass the in-harness resistance to run the black motors coil. Plus change the thermostat housing to the red motors one, and use a different fan and spacer if you keep the black motors water pump.
If you are to change the flywheel/flex
#8 Posted : Friday, 11 January 2008 10:24:41 PM(UTC)
And you'll need to bypass the in-harness resistance to run the black motor's coil. Plus change the thermostat housing to the red motor's one, and use a different fan and spacer if you keep the black motor's water pump.
hgkid1 Offline
#9 Posted : Saturday, 12 January 2008 8:13:18 PM(UTC)
hgkid1
hmm that sounds slightly more difficult. that car is an HG yes. it currently has a standard red carb motor i want to put a 3.3 e.f.i (from Vk Calais) in there not carb. does this motor have an Hei dizzy with it as standard or do i need to buy one? the car
peter_flane Offline
#10 Posted : Saturday, 12 January 2008 9:09:22 PM(UTC)
peter_flane
I put a 3.3 efi in the EH Limo. The physical engine bolts in, once we changed the sump and oil pickup to EH, but there is so much more once you go efi. We used the efi wiring loom and computer, also had to put efi fuel pump, swirl pot, return fuel line, s
#11 Posted : Saturday, 12 January 2008 11:24:52 PM(UTC)
HG 3-speed is externally almost identical to the aussie 4spd. Red 149 through to injected 3.3 EFI are also block wise physically identical so it will bolt straight up to your bellhousing. Aussie 4spd will also bolt onto your bellhousing but needs some flo
hgkid1 Offline
#12 Posted : Tuesday, 15 January 2008 8:45:32 PM(UTC)
hgkid1
thanks for your help guys. still wondering is the wiring something you would do yourself or have done by an auto elec or similar? how does the accelerator connect to the mechanical linkage for the throttle? will this need to be changed if efi is fitted?
#13 Posted : Tuesday, 15 January 2008 10:00:52 PM(UTC)
Wiring is easy to do yourself.
Mechanical linkage is a bit of a problem. Probably best to convery to a pedal off a HJ-WB. I'm actually considering a GenIII into my HK 6cyl GTS at the moment, and the way around the cable throttle issue I have come up with
#14 Posted : Tuesday, 15 January 2008 10:00:52 PM(UTC)
Mechanical linkage is a bit of a problem. Probably best to convery to a pedal off a HJ-WB. Im actually considering a GenIII into my HK 6cyl GTS at the moment, and the way around the cable throttle issue I have come up with
#15 Posted : Thursday, 17 January 2008 8:56:19 AM(UTC)
to avoid the rego problems use your original red block and convert everything off the efi motor you will have to drill 4 holes in the top of the block to use the ehad but it all fits and you keep your original engine number.
hgkid1 Offline
#16 Posted : Thursday, 17 January 2008 7:52:33 PM(UTC)
hgkid1
Thanks that does sounds like a really good idea. Now to find a red block that isn’t stuffed do I still use the same crank and pistons and rods does this mean I do not have to modify the exhaust system if I keep the red block in there?. Will the engine fun
boom Offline
#17 Posted : Thursday, 17 January 2008 8:27:04 PM(UTC)
boom
i've got a red 186 block if you want it.
boom Offline
#18 Posted : Thursday, 17 January 2008 8:27:04 PM(UTC)
boom
ive got a red 186 block if you want it.
#19 Posted : Thursday, 17 January 2008 10:07:55 PM(UTC)
It all bolts into the red 202. Just make sure it's a rope rear main seal 202. Early ones were neoprene seals and blue/black cranks are rope. Red and blue/black blocks are basically identical except for the 3 or 4 water jacket holes mentioned before where
#20 Posted : Thursday, 17 January 2008 10:07:55 PM(UTC)
It all bolts into the red 202. Just make sure its a rope rear main seal 202. Early ones were neoprene seals and blue/black cranks are rope. Red and blue/black blocks are basically identical except for the 3 or 4 water jacket holes mentioned before where t
Guest (13)
