peterwmh Offline
#1 Posted : Monday, 14 January 2008 9:32:39 PM(UTC)
peterwmh
Hi all,
I seem to have a problem with lifters puimping up too much in my old paddock basher HR wagon. The car runs OK and then loses all compression (and stops) as the lifters cause the valves not to seat. If I back them off to where they rattle the car will run again. Can I pull these apart and clean them? If not would anyone have a set they would like to get rid of pretty cheap (don't need to be new just useable). Happy to pay postage. Many thanks Peter
FastEHHolden Offline
#2 Posted : Monday, 14 January 2008 10:50:56 PM(UTC)
FastEHHolden
you could try a wynns lifter product..or use a diesel high detergent oil (but it might leak and be a little smokey if you leave it in too long)
peterwmh Offline
#3 Posted : Monday, 14 January 2008 10:52:30 PM(UTC)
peterwmh
OK not a bad idea, Ive also been told that running diesel as oil for a brief while cleans everything out, but would be a bit weary of doing that!!
Peter
202 and three on the tree, cant get more Aussie than that!!
peterwmh Offline
#4 Posted : Monday, 14 January 2008 10:52:30 PM(UTC)
peterwmh
OK not a bad idea, I've also been told that running diesel as oil for a brief while cleans everything out, but would be a bit weary of doing that!!
Peter
#5 Posted : Tuesday, 15 January 2008 2:18:53 AM(UTC)
FastEHHolden
it cleans all of the carbon out of them..and on an old engine thats not necessarily a good thing...I ruined my first engine doing that.
peterwmh Offline
#6 Posted : Monday, 21 January 2008 10:18:39 PM(UTC)
peterwmh
OK might not do that then, might be the only thing holding the 161 together!!
Peter
peterwmh Offline
#7 Posted : Monday, 21 January 2008 10:18:39 PM(UTC)
peterwmh
Peter
#8 Posted : Tuesday, 22 January 2008 1:08:53 AM(UTC)
you can pull the lifters out and soak them in a solvent such as paint thinners. This might work.
The VL that I had a couple of years ago looked as if it had never had an oil change in fact the inside of the rocker cover had a 10mm thick layer of b
This page was generated in 0.274 seconds.
