clubby677 Offline
#1 Posted : Thursday, 17 January 2008 7:33:31 PM(UTC)
clubby677
Can both of these boxes go behind a 253 in a ute and what would be the benifit of each.
He who dies with the most toys wins!
boom Offline
#2 Posted : Thursday, 17 January 2008 9:07:35 PM(UTC)
boom
yes, and the only difference is the ratios
boom Offline
#3 Posted : Thursday, 17 January 2008 9:07:35 PM(UTC)
boom
JBM Offline
#4 Posted : Thursday, 17 January 2008 9:17:13 PM(UTC)
JBM
There are 2 versions of the M20, 1 for a V8 and 1 for a 6, the difference is the input shaft.
James
boom Offline
#5 Posted : Thursday, 17 January 2008 9:18:43 PM(UTC)
boom
isn't the M21 the GTR box?
boom Offline
#6 Posted : Thursday, 17 January 2008 9:18:43 PM(UTC)
boom
isnt the M21 the GTR box?
JBM Offline
#7 Posted : Thursday, 17 January 2008 9:25:44 PM(UTC)
JBM
M20 were the common box behind the 202 but were also used for the 253. The 308 used the M21. I not sure about the M21 in the XU1, whichever box you use will need to have the correct shaft, 1 is longer than the other.
James
#8 Posted : Thursday, 17 January 2008 10:05:59 PM(UTC)
Was thanked: 611 time(s) in 578 post(s)
You'll rarely find a genuine XU-1 M21. Most were fitted with the normal XU-1 box with the 899 cluster and 1.25:1 3rd gear.
As to the original question, any V8 M20, M21 or even a made up M22 will fit. they are externally the same. Unless you have a 3.55 d
#9 Posted : Thursday, 17 January 2008 10:05:59 PM(UTC)
Youll rarely find a genuine XU-1 M21. Most were fitted with the normal XU-1 box with the 899 cluster and 1.25:1 3rd gear.
As to the original question, any V8 M20, M21 or even a made up M22 will fit. they are externally the same. Unless you have a 3.55 di
Dr Terry Online
#10 Posted : Thursday, 17 January 2008 10:22:04 PM(UTC)
Hi Byron.
The XU-1 box (899 cluster) was called the M20 as you say, but have you ever seen an XU-1 body tag or any paperwork to suggest that any of the other XU-1 boxes were called an M21.
Have you ever seen or known of any XU-1 that came from the f
Edited by user Thursday, 17 January 2008 10:23:19 PM(UTC)  | Reason: Not specified
#11 Posted : Friday, 18 January 2008 8:14:44 AM(UTC)
Terry
I have always called them M20 as a GTR XU-1 has nothing on the body plate, meaning the box is standard. But apparantly the 899 cluster XU-1 box was simply called an XU-1 4spd. Not M20 or M21.
I call the 1.38:1 3rd gear 6cyl box an M21 as it is i
Dr Terry Online
#12 Posted : Friday, 18 January 2008 6:12:01 PM(UTC)
Hi Byron.
I have seen several XU-1s with M20 on the body plate. I believe this was only done at the Adelaide factory, in late LJ production.
AFAIK there were 3 different ratio sets homologated for the XU-1 including the 2.32 1st gear type box.
AF
#13 Posted : Friday, 18 January 2008 8:24:21 PM(UTC)
I understand the M20 BODY plate bit. What I meant was Holden would appear to have never seen the XU-1 box as anything other than an M20, even though it was a different ratio. The fact late Elizabeth cars have M20 makes it seem even clearer. To be 100% cor
Snotty Nosed Vulture Offline
#14 Posted : Friday, 18 January 2008 10:13:27 PM(UTC)
i have always sold 2.32 1st gear 6 cyl boxes as "bathurst" boxes.
to avoid confusion.
these boxes usually have yellow paint XU on the side.
"I can circle for days"
#15 Posted : Saturday, 19 January 2008 12:09:13 AM(UTC)
I'm surprised you've ever found one. They were so rare the input shaft never even got a part number. It was a homologation option only for 1973 Bathurst XU-1's. I'd be surprised if more than a dozen ever existed.
#16 Posted : Saturday, 19 January 2008 12:09:13 AM(UTC)
Im surprised youve ever found one. They were so rare the input shaft never even got a part number. It was a homologation option only for 1973 Bathurst XU-1s. Id be surprised if more than a dozen ever existed.
___________________________________________
#17 Posted : Saturday, 19 January 2008 12:26:42 AM(UTC)
i would have owned / sold 4-5 of them,
2.32 1st gear 6 cyl boxes.
so they must have been more common than that.
my 5/72 car also had one in it - not saying it was factory thou..
boom Offline
#18 Posted : Saturday, 19 January 2008 12:38:53 AM(UTC)
boom
so you single handedly dealt with half of the X-U1 boxes? i think you may be mistaking it for another box.
boom Offline
#19 Posted : Saturday, 19 January 2008 12:38:53 AM(UTC)
boom
#20 Posted : Saturday, 19 January 2008 12:57:59 AM(UTC)
Are you sure you're not talking about standard XU-1 boxes with the 899 cluster? The 2.32:1 1st gear box has a cluster unique to this box and an L34 race box. Input shaft part number starts with EREW
_____________________________________________________
Guest (6)
