coley13 Offline
#1 Posted : Thursday, 17 January 2008 11:32:15 PM(UTC)
coley13
i've got a 4 speed. has 1 groove on input shaft, serial no 9938391. it says holden 6 on main housing but it definatly is a V8 input shaft. it is also the box that has an "oring and seal" selector shafts, NOT the one with 2 orings.
anyways my problem is a broken clip between 2nd and 3rd gears and it can no longer be purchased "from what i've been told by holden".
i'm wondering if i can use a clip from the input shaft bearing. it is wider, but i've checked and the wider clip will fit with clearance if i had the groove machined tu suit. look closely at the third picture where i have the wider clip in between. there is still a little clearance but i'm not sure on how much end float i should have or even if this idea is feasable. if it works i'd have a more heavy dudy clip aswell.
any transmission gurus advice would be great on the matter or maybe know of a simple easy fix
Edited by user Friday, 18 January 2008 4:55:32 PM(UTC)  | Reason: Not specified
boom Offline
#2 Posted : Thursday, 17 January 2008 11:42:15 PM(UTC)
boom
nice tatt
boom Offline
#3 Posted : Thursday, 17 January 2008 11:42:15 PM(UTC)
boom
nice tatt
#4 Posted : Friday, 18 January 2008 12:38:43 AM(UTC)
I have never rebuilt one of these gearboxs before but rebuilt plenety of truck gearboxes and hydrualics for mining equipment, 99% of stuff is built to a standard not just random sizes you should be able to get the clips you need from a fastner or bearing
Dr Terry Online
#5 Posted : Friday, 18 January 2008 2:04:10 AM(UTC)
Hi coley
What bundy said will sort your circlip problem, but that front shaft part number is a bit strange.
You have 9938391, but the closest genuine number I can find is 9930921, which is the front shaft for a 6-cyl M22.
coley13 Offline
#6 Posted : Friday, 18 January 2008 5:30:25 AM(UTC)
coley13
i've checked all the spares places, bearing shops and transmission people in town with no luck.
if anyone has this clip i'm after or knows of where to get one let us know. i'd prefer to get the right one so i dont have to modify anything.
cheers c
coley13 Offline
#7 Posted : Friday, 18 January 2008 5:30:25 AM(UTC)
coley13
ive checked all the spares places, bearing shops and transmission people in town with no luck.
if anyone has this clip im after or knows of where to get one let us know. id prefer to get the right one so i dont have to modify anything.
cheers crai
JBM Offline
#8 Posted : Friday, 18 January 2008 7:31:26 AM(UTC)
JBM
In relation to the circlip have tried specialty fastener places like Coventry, Mullings or Blackwoods?
James
coley13 Offline
#9 Posted : Friday, 18 January 2008 10:04:43 PM(UTC)
coley13
found the clip i was after, it was from an old mechanic who had a genuine holden rebuild kit still floating around thankfully cheers craig
Guest (5)
