78XC Offline
#1 Posted : Friday, 18 January 2008 8:35:32 AM(UTC)
78XC
ok I bought this xc and I was told that it has a lsd 9 inch one the reasons for buying the thing. Now I'm not sure that it's limo, the guy told me it's open wheeler now cause the clutches are gone and I'm ok with that BUT I jacked the rear off the ground and turned one wheel and the other one whent opposite in direction I thought they were supposed to go the same way if limo. So the from looking at it the housing is 9 inch. So is it cause the cluthces are gone that it's gone to open wheeler or did I stung?
Any help would be appreciative.
#2 Posted : Friday, 18 January 2008 8:58:47 AM(UTC)
sounds like you were dudded but does it have the sticker or tag on the diff that says lsd/ otherwise you have to pull the centre and see if it has clutches which you would have to do anyway to fix it.
78XC Offline
#3 Posted : Saturday, 19 January 2008 3:47:29 AM(UTC)
78XC
noooooooooooooooooooooooooo whyyyyyyyyyyyyyyyyyyy i have to check if it has a tag i looked before but didn't notice any I'll have to check properly thankyou for your post.
XB351 Offline
#4 Posted : Saturday, 19 January 2008 5:07:36 PM(UTC)
XB351
Even a dead LSD will still spin the same way. You have a single wheeler diff without any doubt.
#5 Posted : Saturday, 19 January 2008 8:53:06 PM(UTC)
I once bought a car and it had a 9 inch,I was told it was an open centre by the seller,anyway I jacked the car up and spun one wheel in the forward direction and the other wheel either did'nt move or went in the opposite direction.Years later I opened it
78XC Offline
#6 Posted : Sunday, 20 January 2008 3:50:53 AM(UTC)
78XC
yeah I think that really is the only way. thanks for your help Guys I more then likely got done. we will see!!!!!!!!
#7 Posted : Tuesday, 22 January 2008 8:04:04 AM(UTC)
I am sure that my Lsd spins opposite, I have aq fresh 1 and a rooted 1, and will check them out 4 u, I think you may have an Lsd?
78XC Offline
#8 Posted : Wednesday, 23 January 2008 4:24:12 AM(UTC)
78XC
thanks superbird that would be great a really appreciate it.
keithholden Offline
#9 Posted : Wednesday, 23 January 2008 6:48:38 PM(UTC)
keithholden
Id be keen to know as well superbird in case someone has changed the centre of my diff and put the tag on from a previous one.
XB351 Offline
#10 Posted : Sunday, 27 January 2008 5:40:31 PM(UTC)
XB351
I've got a stuffed LSD here and it was brand new 7 years ago. It now spins only 1 wheel and still when turned by hand both wheels go forward. I put in a detroit locker mid 07 due to the LSD not being able to handle the power over a long period of time.
#11 Posted : Sunday, 27 January 2008 10:05:52 PM(UTC)
Sorry to get your hopes up, I stand corrected. They both spin in the same direction!
78XC Offline
#12 Posted : Thursday, 31 January 2008 6:07:48 AM(UTC)
78XC
yeah I think I got done. Oh well not much else I think I could of done when buying the damn think as it is a 9 inch housing and I didn't have the jack with me. oh well you live and learn. thanks guys for all your help.
Guest (5)
