wallywa Offline
#1 Posted : Sunday, 20 January 2008 11:00:59 AM(UTC)
wallywa
Just after a bit of info on ABS module in a VT Gen3 .First of all where are they located ? And i have read in these forums that they can be responsible for a number of different warning lights coming on the dash is this correct?
Mark
Mark
#2 Posted : Sunday, 20 January 2008 9:00:48 PM(UTC)
Hi Mark.
The ABS 'module' on VT/VX/VY is the black plastic front section of the ABS actuator/pump unit on the driver's side underbonnet.
Yes, one of the common faults is that many of the dash warning lights come on for no reason. In extreme cases,
#3 Posted : Sunday, 20 January 2008 9:00:48 PM(UTC)
Hi Mark.
The ABS module on VT/VX/VY is the black plastic front section of the ABS actuator/pump unit on the drivers side underbonnet.
Yes, one of the common faults is that many of the dash warning lights come on for no reason. In extreme cases, the
#4 Posted : Tuesday, 22 January 2008 7:00:33 PM(UTC)
Hey do you know if a ABS module with any of these numbers will go in a VT Commodore 3.8l V6?
92093867, 92093871?
send emails too: [email protected]
#5 Posted : Tuesday, 22 January 2008 7:23:23 PM(UTC)
Hi Radio Head
I dont have a listing in GM part numbers. I use the Bosch numbers which are actually on the white barcode label on the modules black plastic case.
If you quote me those numbers I can tell you which is which.
Dr Terry.
#6 Posted : Tuesday, 22 January 2008 7:23:23 PM(UTC)
Hi Radio Head
I don't have a listing in GM part numbers. I use the Bosch numbers which are actually on the white barcode label on the module's black plastic case.
Dr Terry.
#7 Posted : Wednesday, 23 January 2008 8:58:41 PM(UTC)
Hi Dr Terry
I don't now which numbers you need so I will quote them all:
11986
291501
0 273 004 588
Radio Head
#8 Posted : Wednesday, 23 January 2008 8:58:41 PM(UTC)
Hi Dr Terry
I dont now which numbers you need so I will quote them all:
11986
291501
0 273 004 588
Radio Head
#9 Posted : Wednesday, 23 January 2008 9:00:14 PM(UTC)
P.S
Those numbers are off the one module
#10 Posted : Wednesday, 23 January 2008 9:26:34 PM(UTC)
Hi all,
I seem to suffering the same problem in my series 2 VT Calais.
Two questions, Does anyone know where I could get a change over unit in Adelaide ?
If I just pull the ABS fuse under the dash ( as a temp fix ) will this affect any other funtions,o
#11 Posted : Wednesday, 23 January 2008 9:40:01 PM(UTC)
Hi Radio Head.
My listing says that an 0 273 004 588 suits a VY V6 WITHOUT TRACTION CONTROL, so this will not work in your VT V6, if yours has traction control. A VT V6 with traction requires an 0 273 004 348 or a 0 273 004 485
Phil M, to stop the A
#12 Posted : Thursday, 24 January 2008 2:00:58 AM(UTC)
Thanks Dr Terry,
I did try that yesterday but that seemed to give me the same fault lights as when it plays up,but if I just pulled the under dash fuse it only gave me the ABS and Traction off lights.
I have noticed on other parts of the forums that you
#13 Posted : Thursday, 24 January 2008 5:23:01 AM(UTC)
Hi Dr Tery
Thanks heaps.
