V2?
#1 Posted : Wednesday, 23 January 2008 12:59:41 AM(UTC)
My sound stupid but why would i use a V2 head... in relation to ford 200's and 250's. Obviusly its got 2 valves per cyl, but are the larger than normal??? what is so good bout them?
Paul351xb Offline
#2 Posted : Wednesday, 23 January 2008 1:51:34 AM(UTC)
Paul351xb
Have you got 2V head sitting in the shed?
#3 Posted : Wednesday, 23 January 2008 1:55:54 AM(UTC)
no I dont but have access to one if i want it... should i want it? plz explain
Paul351xb Offline
#4 Posted : Wednesday, 23 January 2008 2:06:50 AM(UTC)
Paul351xb
The 2V head gives the standard 250 quite a bit more punch. Some say a well tuned one will pull even with a 302. I don't know much about them though I have heard there is a bit of a demand for these heads from the USA as the 2V is pretty much an Aussie o
Paul351xb Offline
#5 Posted : Wednesday, 23 January 2008 2:54:10 AM(UTC)
Paul351xb
www.earlyfalcons.com Offline
#6 Posted : Wednesday, 23 January 2008 7:25:54 AM(UTC)
A 2V head can be put on a 221 & 250, will also fit on earlier ones but no great advantage. The yanks are now producing their own new 2V heads, from memory are alloy.
6pak Offline
#7 Posted : Wednesday, 23 January 2008 10:22:26 AM(UTC)
6pak
Hi, My understanding of the 2V name is related to "two venturi" as they were fitted with a two barrel carb (they also have a bolt on manifold instead of the cast in "log" type on the regular cylinder head. My friend had an XY Fairmont with a 2V 250 in it
#8 Posted : Thursday, 24 January 2008 8:06:58 PM(UTC)
thanks for your help boys! are the V2 heads hard to come by? any ideas on where i might be able to find one?
6pak Offline
#9 Posted : Friday, 25 January 2008 7:47:22 AM(UTC)
6pak
Hi XM, Superoo falcon spares in Perth have several acres of old heaps around their premises. They may have one in the corner somewhere. Google them for their site and drop em an e-mail.
Bossy Offline
#10 Posted : Sunday, 27 January 2008 2:59:05 AM(UTC)
Bossy
Superoo have been fantastic in the renovation of my XP. Even their freight charges to the East Coast are reasonable.
