#1 Posted : Thursday, 24 January 2008 2:39:55 AM(UTC)
in choosing a 308 block a choice has to be made a turbo or a trimatic as one can now get beefed up trimatics which block should i choose cheers ps its only going to be a warm 308
The Yeti Offline
#2 Posted : Thursday, 24 January 2008 2:46:49 AM(UTC)
The Yeti
Ithink you will find Turbo boxes are cheaper to get tricked up so I would go that way but sayign that I have a tidy traumatic I will be putting behind my tramatic pattern block
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
#3 Posted : Thursday, 24 January 2008 8:09:12 AM(UTC)
A trimatic would do the job, turbo`s are stronger and dearer to buy.
#4 Posted : Thursday, 24 January 2008 4:41:12 PM(UTC)
Hi Guys.
Remember there are 2 different 'Turbo' boxes, the Turbo-Hydramatic 350 & Turbo-Hydramatic 400. They are not the same. The TH400 is a very strong durable box, good for heavy drag cars, where a 3-speed is needed. The TH350 is a lightweight by co
#5 Posted : Thursday, 24 January 2008 4:41:12 PM(UTC)
Hi Guys.
Remember there are 2 different Turbo boxes, the Turbo-Hydramatic 350 & Turbo-Hydramatic 400. They are not the same. The TH400 is a very strong durable box, good for heavy drag cars, where a 3-speed is needed. The TH350 is a lightweight by comp
JBM Offline
#6 Posted : Thursday, 24 January 2008 5:07:38 PM(UTC)
JBM
In regards to Tri-matics being underrated the design was bought by Rolls-Royce.
James
Mr.Jones Offline
#7 Posted : Thursday, 24 January 2008 8:11:47 PM(UTC)
Mr.Jones
JBM, Rolls and Jag both used TH400s because of their strength and shift quality.
John what box would depend on your application, the car its going into ie the weight, Id go for trimatic unless you have a stato or do lots of towing, but make sure you have
Voltaire
Mr.Jones Offline
#8 Posted : Thursday, 24 January 2008 8:11:47 PM(UTC)
Mr.Jones
JBM, Rolls and Jag both used TH400's because of their strength and shift quality.
John what box would depend on your application, the car its going into ie the weight, I'd go for trimatic unless you have a stato or do lots of towing, but make sure you ha
Voltaire
#9 Posted : Thursday, 24 January 2008 10:03:59 PM(UTC)
I'd always choose the TH400, except in a light car like a Torana.
#10 Posted : Thursday, 24 January 2008 10:03:59 PM(UTC)
Id always choose the TH400, except in a light car like a Torana.
#11 Posted : Thursday, 24 January 2008 10:21:34 PM(UTC)
As Byron said..
TH400 were factory fitted to engines from 308-502 cubic inch.
Tough as gutz..!!
Trihard boxes were fitted on engines up to 308 at the most.
Gotta spend quite a few $$ to get them to hold up to a strong motor.
Under-rated or no
#12 Posted : Thursday, 24 January 2008 10:41:15 PM(UTC)
Originally posted by Luke
As Byron said..
Tough as
#13 Posted : Friday, 25 January 2008 5:56:00 AM(UTC)
Well Mr Dr Terry,
I dont agree with you at all.....
I think the TH350 is an excellent trans and much better than a trihard box
I have had several boxes built for race cars over the years and are as yet to hear from a trans expert that a crummy ol
#14 Posted : Friday, 25 January 2008 5:56:00 AM(UTC)
Well Mr Dr Terry,
I don't agree with you at all.....
I have had several boxes built for race cars over the years and are as yet to hear from a trans 'expert' that a crummy
boom Offline
#15 Posted : Friday, 25 January 2008 6:47:34 AM(UTC)
boom
why? some of the raceglides today have been able to handle 800+hp with the same rebuilds as turbo boxes. Trimatics are light, soak up less power, and all transmissions cost the same to trick up when you go for big power anyway, so why not go with somethin
#16 Posted : Friday, 25 January 2008 6:10:47 PM(UTC)
Well Mr Dr Terry,
#17 Posted : Friday, 25 January 2008 6:10:47 PM(UTC)
Well Mr Dr Terry,
Rhys Offline
#18 Posted : Friday, 25 January 2008 7:22:03 PM(UTC)
Rhys
Hi Dr Terry,
Are there any tricks to get a trimatic as 'smooth' as a TH400 (eg different type of clutches etc)? I have 3 WBs with V8 Trimatics and the upshifts and downshifts are no where near as smooth as the TH400 in my HQ. Other than that I am very
Rhys Offline
#19 Posted : Friday, 25 January 2008 7:22:03 PM(UTC)
Rhys
Hi Dr Terry,
Are there any tricks to get a trimatic as smooth as a TH400 (eg different type of clutches etc)? I have 3 WBs with V8 Trimatics and the upshifts and downshifts are no where near as smooth as the TH400 in my HQ. Other than that I am very ha
boom Offline
#20 Posted : Friday, 25 January 2008 11:18:31 PM(UTC)
boom
I believe raceglides in melboure does a kit that completely fixes all the mess that holden left the trimatic with from factory, e.g. a second ring in 1st gear piston stops in leaking, more clutch packs in 2nd and 3rd (IIRC they used seven in 3rd gear) and
This page was generated in 0.110 seconds.
