2 Pages<12
BAD WB Offline
#21 Posted : Saturday, 26 January 2008 1:24:06 AM(UTC)
BAD WB
Can any one tell me how may HP it takes to rn a trimatic. I was told a turbo 400 uses 50hp and a turbo 350 uses 37hp. just wandering if i should go a trimatic in my ute instead of a th400? which one will get more power to the ground?
Cheers.
boom Offline
#22 Posted : Saturday, 26 January 2008 1:31:24 AM(UTC)
boom
trimatic will definitely use less power than a turbo 400. how much, i am uncertain. but i think you'd lose 20% through the driveline with a tri, don't quote me because i am not 100%.
If nissan motorsport is nismo, then doesn't that
boom Offline
#23 Posted : Saturday, 26 January 2008 1:31:24 AM(UTC)
boom
trimatic will definitely use less power than a turbo 400. how much, i am uncertain. but i think youd lose 20% through the driveline with a tri, dont quote me because i am not 100%.
If nissan motorsport is nismo, then doesnt that ma
BAD WB Offline
#24 Posted : Saturday, 26 January 2008 1:39:20 AM(UTC)
BAD WB
WHy would youloose more through the drive line with a trimatic rather than a turbo?
boom Offline
#25 Posted : Saturday, 26 January 2008 1:40:59 AM(UTC)
boom
you wouldn't?
boom Offline
#26 Posted : Saturday, 26 January 2008 1:40:59 AM(UTC)
boom
you wouldnt?
#27 Posted : Saturday, 26 January 2008 2:12:47 AM(UTC)
thanks for all the info guys it seems you cant go wrong with either box if get the right one the only real trouble ive had with them behind a 6 is there sensativity to vacuum thumping from 2nd to low and destroying everything behind it unies and banjo dif
Guest (9)
2 Pages<12
