hazzard county Offline
#1 Posted : Sunday, 27 January 2008 12:03:48 AM(UTC)
hazzard county
are all hk t g leaf springs the same lenght wagon,ute,sedan etc
#2 Posted : Sunday, 27 January 2008 2:38:22 AM(UTC)
Hi hazzard.
Yes & no.
They are all the same length from centre to centre of the bolts. Some (HT onwards) have a larger front spring eye, so that the 'total' length would be more. Also, the springs with the larger spring eyes will not fit the bodies
#3 Posted : Sunday, 27 January 2008 2:38:22 AM(UTC)
Hi hazzard.
Yes & no.
They are all the same length from centre to centre of the bolts. Some (HT onwards) have a larger front spring eye, so that the total length would be more. Also, the springs with the larger spring eyes will not fit the bodies de
#4 Posted : Sunday, 27 January 2008 3:12:08 AM(UTC)
hazzard county
thanks dr terry also is there a difference between manual & auto cars meaning the number of leafs in the monaro range
#5 Posted : Sunday, 27 January 2008 7:28:04 AM(UTC)
Hi hazzard.
You only asked about length, the number of leaves varies a lot.
Wagons have more leaves, ute & vans even more.
Dr Terry.
81837 Offline
#6 Posted : Sunday, 27 January 2008 7:22:31 PM(UTC)
81837
My Brougham had the "dragging its arse" look when I bought it, it had the normal 3 leaf rear springs. I got some 6 leaf springs from a station wagon which fixed this nicely. You will need to get the spacers that go between the diff pad and lower saddle to
#7 Posted : Sunday, 27 January 2008 9:59:57 PM(UTC)
Was thanked: 612 time(s) in 579 post(s)
In HK most GTS had the same springs, but Monaros start to differ greatly in late HK.
Guest (5)
