are all hk t g leaf springs the same lenght wagon,ute,sedan etc
Hi hazzard.
Yes & no.
They are all the same length from centre to centre of the bolts. Some (HT onwards) have a larger front spring eye, so that the 'total' length would be more. Also, the springs with the larger spring eyes will not fit the bodies |
Hi hazzard.
Yes & no.
They are all the same length from centre to centre of the bolts. Some (HT onwards) have a larger front spring eye, so that the total length would be more. Also, the springs with the larger spring eyes will not fit the bodies de |
thanks dr terry also is there a difference between manual & auto cars meaning the number of leafs in the monaro range
Hi hazzard.
You only asked about length, the number of leaves varies a lot.
Wagons have more leaves, ute & vans even more.
Dr Terry. |
My Brougham had the "dragging its arse" look when I bought it, it had the normal 3 leaf rear springs. I got some 6 leaf springs from a station wagon which fixed this nicely. You will need to get the spacers that go between the diff pad and lower saddle to
In HK most GTS had the same springs, but Monaros start to differ greatly in late HK.
