BorisHJ Offline
#1 Posted : Sunday, 27 January 2008 1:15:18 AM(UTC)
BorisHJ
hi all, i resently converted my 3 speed colum shift to a 5 speed floor shift, the only problem is i cant work out how to get the old gear stick out of the steering colum, can any one help, its a 1975 HJ kingswood,
Luke
#2 Posted : Sunday, 27 January 2008 3:18:42 AM(UTC)
Was thanked: 612 time(s) in 579 post(s)
Best way is to buy a floor shift column and replace it.
wombat1 Offline
#3 Posted : Sunday, 27 January 2008 8:08:32 AM(UTC)
wombat1
you have to punch the pin out in the lever to steering column
with a punch and hammer ..
wombat
BorisHJ Offline
#4 Posted : Sunday, 27 January 2008 9:43:20 AM(UTC)
BorisHJ
seems easy enough, thanks for the help fellas
Luke
#5 Posted : Tuesday, 29 January 2008 11:08:22 AM(UTC)
the pins are really hard to knock out you generally break something, and end up with an ugly housing, better to remove the whole housing anf replace with a smooth one.
ozjason Offline
#6 Posted : Wednesday, 30 January 2008 12:18:02 AM(UTC)
ozjason
Thought for you... it can be left there as a kill switch thats not obvious. Use the reverse light switching on the column shift as a secret kill mechanism. Put it in reverse position when youre stopped. Move out to go again.
Also looks cool. :-)
ozjason Offline
#7 Posted : Wednesday, 30 January 2008 12:18:02 AM(UTC)
ozjason
Thought for you... it can be left there as a kill switch that's not obvious. Use the reverse light switching on the column shift as a secret kill mechanism. Put it in reverse position when you're stopped. Move out to go again.
BorisHJ Offline
#8 Posted : Wednesday, 30 January 2008 2:21:24 AM(UTC)
BorisHJ
do you need to take the stick out to to change the housing or does it come out as one peice?
Luke
#9 Posted : Wednesday, 30 January 2008 9:48:21 AM(UTC)
remove steering wheel, do NOT hammer the nut to remove it or jar it, you will destroy the column, use a puller can be made up with a bit of scrap steel and 3 bolts, or buy one, the remove the housings and disconnect the gear change rods then remove the ch
BorisHJ Offline
#10 Posted : Thursday, 31 January 2008 1:45:56 AM(UTC)
BorisHJ
ok thanks for that, ill have a look at rare spares for a blank spacer thats prob the easiest way. ill let u know how it goes
Luke
