Absinth Offline
#1 Posted : Monday, 28 January 2008 3:04:15 AM(UTC)
Absinth
Hi all, I am looking for anyone that has an early HQ GTS 140mph speedo that is broken or not working that they would sell to me. I only need the face and the needle with the black disc on it..IE a correct GTS speedo.
So far I have bought 4 HQ GTS dashes and only one has come with a correct 140mph speedo but the seller ripped me and changed the needle for a standard one. He reckons the disc must have fallen off as the speedo didn't have a lens on it. Almost believable except the needles are different shapes....
Any help much appreciated.
I have re-built the HQ speedo above and also the following.
HT GTS Monaro speedo
HX GTS Monaro speedo
Looks like I need to polish the plastic lens a little more, missed a few scratches.
EH speedo and gauges
All have been fully cleaned, any worn parts replaced and then re-calibrated.
Edited by user Monday, 4 February 2008 8:13:59 PM(UTC)  | Reason: Not specified
#2 Posted : Monday, 28 January 2008 8:14:09 AM(UTC)
Have you seen what HQ 140mph speedo`s are selling for on ebay up to $400. thats just the speedo !
Absinth Offline
#3 Posted : Tuesday, 29 January 2008 7:35:04 AM(UTC)
Absinth
Yes, stupid prices considering most of them are worn out and most have broken mounting tabs. All four HQ speedos I have needed rebuilding. By the time you spend $200 having it rebuilt and calibrated and another $60 or so for new plastic lenses they arent
Absinth Offline
#4 Posted : Tuesday, 29 January 2008 7:35:04 AM(UTC)
Absinth
Yes, stupid prices considering most of them are worn out and most have broken mounting tabs. All four HQ speedo's I have needed rebuilding. By the time you spend $200 having it rebuilt and calibrated and another $60 or so for new plastic lenses they aren'
#5 Posted : Tuesday, 29 January 2008 11:04:20 AM(UTC)
themounting cases are all the same so broken tabs are not a problem, will have a look I have a box of early/late Q speedos and instrument housing gts and standard.
what did you use to polish the scratches out?
Absinth Offline
#6 Posted : Wednesday, 30 January 2008 12:03:35 AM(UTC)
Absinth
Hi John, yes I know the cases are the same but you still need to buy a standard speedo with a good case and lense for a donor unless you happen to have one lying around.
I use NOVUS 3 stage plastic polish. No. 3 is heavy scratch remover, No. 2 is fine
Absinth Offline
#7 Posted : Wednesday, 30 January 2008 3:38:55 AM(UTC)
Absinth
Well, I fixed my needle problem by modifying a HX GTS speedo needle. HQ GTS speedo came up real nice now fully rebuilt, calibrated and original lens polished up. Almost looks new.
adam PERTH Offline
#8 Posted : Wednesday, 30 January 2008 4:03:52 AM(UTC)
adam PERTH
i have a complete 140 MPH dash, with clock, NOS facia if interested
0419934767
A1 Bogan.
