hz dude Offline
#1 Posted : Tuesday, 29 January 2008 8:01:38 AM(UTC)
hz dude
First off what sort of box are they ML4 code on the plate ?
And why did they have linkage or cable ,when was the change over ?
Just change motor and box in a VL and there was so many differnces
between the 2 motors and the same for the 2 boxs, different power steer pump,
oil pressure sendor, different shifter setup and didnt notice that things
had to be changed till it was all in so what a pain in the butt.
#2 Posted : Tuesday, 29 January 2008 8:08:22 AM(UTC)
Hi hz dude.
There were many small changes made during the VL production run. AFAIK the change from cable shift to rod shift occurred around Nov '86. The ML4 auto trans used was a Jatco 4-speed.
There were 2 different types of P/St pumps used on VL 6
Edited by user Tuesday, 29 January 2008 8:09:19 AM(UTC)  | Reason: Not specified
#3 Posted : Tuesday, 29 January 2008 8:08:22 AM(UTC)
Hi hz dude.
There were many small changes made during the VL production run. AFAIK the change from cable shift to rod shift occurred around Nov 86. The ML4 auto trans used was a Jatco 4-speed.
There were 2 different types of P/St pumps used on VL 6-
hz dude Offline
#4 Posted : Wednesday, 30 January 2008 7:15:41 AM(UTC)
hz dude
thanx DR TERRY but why on the oil pressure sender did they run a duel
wire for both senders was it for (just in case) or was there a reason
thanx again
On The Other Hand Theres Fingers
hz dude Offline
#5 Posted : Wednesday, 30 January 2008 7:15:41 AM(UTC)
hz dude
thanx again
