BorisHJ Offline
#1 Posted : Tuesday, 29 January 2008 9:02:41 AM(UTC)
BorisHJ
hi all, im lookin at upgrading the breaks on my HJ kingswood, im pretty sure they are the stock breaks disc on one end, i was told that its a good idea to upgrade just wondering if any one could give me any pointers is it worth doing?, hopefully something that wont break the bank.
Luke
#2 Posted : Tuesday, 29 January 2008 9:17:41 AM(UTC)
Hi Boris if its mainly used for daily driving give them a birthday by getting better pads change the fluid to a higher performance one, finally new front rotors if needed maybe dba sports.
good luck Leroy
BorisHJ Offline
#3 Posted : Tuesday, 29 January 2008 9:37:26 AM(UTC)
BorisHJ
so just a bit of a service and some new rotors and they will be alright, thats alright, would that set me back much money wise, whats a set of rotors worth ?
thanks for ur help
Luke
#4 Posted : Tuesday, 29 January 2008 4:13:10 PM(UTC)
check out some of the ebay rotor prices some are cheaper than the auto shops, ring around and check ebay as the prices vary a great deal for the same brands.
#5 Posted : Tuesday, 29 January 2008 4:13:25 PM(UTC)
Rotors are about $75 to $200 each depending up what you get. Go to the Disc Brakes Australia website and have a look. Fit new wheel bearings whilst your at it, get the front calipers pulled apart, cleaned out and a new seal kit fitted, new fluid and new r
trubluhq Offline
#6 Posted : Tuesday, 29 January 2008 7:01:52 PM(UTC)
trubluhq
Upgrade ?? Those brakes should be fine. I find my HQ Prem can outbrake the Calais. Has a better feel, feels solid and no crappy ABS to get in the way.
Maybe change your pads (front & rear), and make SURE that the rears are working and adjusted properly
BorisHJ Offline
#7 Posted : Wednesday, 30 January 2008 2:25:39 AM(UTC)
BorisHJ
thanks for all ur help fellas, i will take it all into consideration, i mean there doesnt appear to be any thing wrong with the breaks at the moment, i was just told that its a good idea to upgrade, think ill just get the pads changed and things like that
