Slamd Hk Offline
#1 Posted : Tuesday, 29 January 2008 11:30:16 PM(UTC)
Slamd Hk
You are a member of these groups:: Registered
Hi All,
My VT (V6) exec has been cutting out while trying to start.
What i mean is you crank it , it fires for a split sec & cuts out & you can hear the engine fan kick in. Try again & it is ok. It has just started doing this & thought I should get it sorted asap.
Has anyone dealt with this before?
Slamd Hk
MLD
peterwmh Offline
#2 Posted : Wednesday, 30 January 2008 1:04:01 AM(UTC)
peterwmh
Could be either a crank angle sensor on it's way out (does it do it more often when hot?). Also the fuel filter may be blocked and starves the engine for fuel on startup?
Just a thought
Peter
202 and three on the tree, can't get more Aussie than
peterwmh Offline
#3 Posted : Wednesday, 30 January 2008 1:04:01 AM(UTC)
peterwmh
Could be either a crank angle sensor on its way out (does it do it more often when hot?). Also the fuel filter may be blocked and starves the engine for fuel on startup?
Just a thought
Peter
202 and three on the tree, cant get more Aussie than t
#4 Posted : Wednesday, 30 January 2008 2:11:30 AM(UTC)
Hey Peter, I have only found it to do it on start up from cold or from only being driven around 5 mins (home to the shops & back)around 1/4 on temp gauge.
Slamd Hk
This page was generated in 0.103 seconds.
