hx-sandman Offline
#1 Posted : Wednesday, 30 January 2008 7:17:23 PM(UTC)
hx-sandman
I have a Blue 308 in a WB ute that seems to be quite gutless. It's also getting around 130km to a tank of fuel. It's not being driven hard and the motor doesn't need a rebuild.
Any suggestions on what may be causing it to be so thirsty?
#2 Posted : Wednesday, 30 January 2008 8:07:53 PM(UTC)
Hi hx-sandman.
More info is required. Firstly as the 308 wasn't factory fitted in the WB ute, has it been modified ?
If it has a stock cam & Quadrajet, it probably just needs a carby overhaul (including a new float) & a good tune. If it has a Holley
#3 Posted : Wednesday, 30 January 2008 8:07:53 PM(UTC)
Hi hx-sandman.
More info is required. Firstly as the 308 wasnt factory fitted in the WB ute, has it been modified ?
peterwmh Offline
#4 Posted : Wednesday, 30 January 2008 9:12:48 PM(UTC)
peterwmh
A streched timing chain will do this too, also the blue 308s had a weak camshaft and the lobes may be losing their bump.
Peter
202 and three on the tree, cant get more Aussie than that!!
peterwmh Offline
#5 Posted : Wednesday, 30 January 2008 9:12:48 PM(UTC)
peterwmh
A streched timing chain will do this too, also the blue 308s had a weak camshaft and the lobes may be losing their 'bump'.
Peter
#6 Posted : Wednesday, 30 January 2008 10:24:52 PM(UTC)
They actually have a "weak" oil pump, causing the cam problem.
As well as what Terry has said, make sure the distributor is working correctly, especially the vacuum advance. And that the valve in one side exhaust isn't stuck shut.
____________________
Edited by user Wednesday, 30 January 2008 10:29:22 PM(UTC)  | Reason: Not specified
#7 Posted : Wednesday, 30 January 2008 10:24:52 PM(UTC)
As well as what Terry has said, make sure the distributor is working correctly, especially the vacuum advance. And that the valve in one side exhaust isnt stuck shut.
_____________________
bundybluedog Offline
#8 Posted : Wednesday, 30 January 2008 10:36:45 PM(UTC)
bundybluedog
mine had worn lobes on the cam a half shaged torque convertor, if it been rebuilt to suit unleaded it will have a lower compresion which if its like the one i had with low comp it was slower to rev and i tended to put my boot down a bit more which really
hx-sandman Offline
#9 Posted : Wednesday, 30 January 2008 10:59:49 PM(UTC)
hx-sandman
The motor was from a WB Statesman and has allegedly been built for unleaded. THanks for the advice guys - will check the cam, carb and timing chain, timing may have been retarded a little too.
Edited by user Wednesday, 30 January 2008 11:00:31 PM(UTC)  | Reason: Not specified
JBM Offline
#10 Posted : Wednesday, 30 January 2008 11:02:29 PM(UTC)
JBM
Regarding the weak oil pump how do you know which ones are better. I just bought a disassembled 253 and dont want to rebuild it twice.
James
You only have to be in front at the end of the race
#11 Posted : Thursday, 31 January 2008 4:30:04 AM(UTC)
If it has an alloy housing and its secondhand throw it away and buy a cast iron housing one (aftermarket).
#12 Posted : Thursday, 31 January 2008 4:30:04 AM(UTC)
If it has an alloy housing and it's secondhand throw it away and buy a cast iron housing one (aftermarket).
JBM Offline
#13 Posted : Thursday, 31 January 2008 4:19:54 PM(UTC)
JBM
trubluhq Offline
#14 Posted : Thursday, 31 January 2008 5:08:48 PM(UTC)
trubluhq
Hi HX,
How much vacuum does the engine have ? Low vacuum will effect heaps of things, economy, sluggishness and tranny.
John
#15 Posted : Friday, 1 February 2008 5:54:59 AM(UTC)
If nothing else turns up it may well pay to check that the cam timing is correct. This can easily be set incorrectly on a Holden V8 especially considering that this engine has not long been rebuilt. Hope this helps.
trubluhq Offline
#16 Posted : Saturday, 2 February 2008 3:55:21 AM(UTC)
trubluhq
Worn cam maybe. If you are one link out on a Holden V8 timing it may work. 2 links out and there go your pistons. Wrong ignition timing can do it. Vacuum leak at the dizzy can do it. Major vacuum leak effects timing, tranny and the carby. If vacuum is too
trubluhq Offline
#17 Posted : Saturday, 2 February 2008 3:59:17 AM(UTC)
trubluhq
Another dumb thing I just thought of...BLUE MOTOR....EGR valve issues. Is it in place, or gone or sort of working. If they freeze in the OPEN setting, you get low vacuum all the time. It means bog on hard accel. no get up at all really, and wil use more j
