#1 Posted : Thursday, 31 January 2008 8:04:31 PM(UTC)
Hi All,
I tried starting the VT this morning & it only half cranked over then nothing.Turned key off & cranked a little then nothing.TRied a few more times then all good. Any idea's on what could be doing this at all. It has a new battery (1 month old)
Could this be the crank angle sensor ?
Are they easy to replace ?
Slamd Hk
#2 Posted : Thursday, 31 January 2008 10:42:41 PM(UTC)
Hi Slamd Hk
Despite the similarity in name, the crank angle sensor has nothing to do with the starter motor cranking the engine over.
2 common problems for intermittent cranking are:-
1. Loose starter cable cable where it bolts to the starter sol
#3 Posted : Thursday, 31 January 2008 11:06:08 PM(UTC)
Thanks Dr T,
Will give it a thorough check over this arvo .
Slamd Hk
