#1 Posted : Friday, 1 February 2008 6:54:25 AM(UTC)
does any1 know a rough conversion rate for flywheel - wheels
tah
#2 Posted : Friday, 1 February 2008 11:20:34 AM(UTC)
depends on diff ratio. i.e.,, 3.55 ratio means 3.55 turns of flywheel to one turn of rear wheels or 3550 rpm is 1000 turns of rear wheels.
richo2 Offline
#3 Posted : Sunday, 3 February 2008 3:47:01 AM(UTC)
richo2
You also need to think about the gears that you are using. If you are driving in 1st gear for example, then you would go 1 / (1st gear ratio x diff ratio)
