Does anyone know where which country the genuine 14 x 6 HQ GTS wheels were made ? also does anyone in syney restore these wheels ??? " Smokem Baby " Edited by user Friday, 1 February 2008 7:06:05 AM(UTC)
| Reason: Not specified |
" Smokem Baby " |
The 71/2 wheels were made in Canada, the later wheels made here.
Warren
i have 73 dated rim and where the whole for the needle is on the rim it has stamped made in japan and the part number , where any made in japan , could this be correct warren , i will take a picture and post , funny though the made in japan is stamped Edited by user Friday, 1 February 2008 9:10:49 AM(UTC)
" Smokem Baby " |
Hi Clearway,
The Canadian rimes were stamped "6.00JK Made in Canada" They have one safety bead around the rim ONLY.
The HOLDEN ones were stamped "HOLDEN 6.00JJ 3/74". They have TWO safety beads around the rim, and there are 3 or 4 welds on the insid
a guy was selling a canadian rim at the last swap I went to was asking $40.00 for a bare rim.
how do you post pics on this site ?
here are some pics of the wheels in question dated 1973 and branded PACIFIC made in JAPAN also have HR13 stamped on one side and the No:6 stamped in a circle on the other side , i want to restore them need correct paint codes for my HQ monaro , or som |
" Smokem Baby " |
Note these are off a 2/73 XW8 should i restore them or leave them alone ? Funny Date code 0/73 ( wink) !!!!!
" Smokem Baby " |
" Smokem Baby " |
Hi Guys.
There is something odd with the way that 'PACIFIC' & 'MADE N JAPAN' is marked on the rim.
It's strange that it's in reverse & it's also concentric with the valve hole. Maybe a tyre pressure monitoring sensor has left that mark.
They look |
Hi Guys.
There is something odd with the way that PACIFIC & MADE N JAPAN is marked on the rim.
Its strange that its in reverse & its also concentric with the valve hole. Maybe a tyre pressure monitoring sensor has left that mark.
They look to me |
Dr Terry all four wheels are the same i have not got to the spare as yet still has tyre on in , if you take a closer look you will see there is a ( guide ) where Pacific and made in japan was stamped. half circle ,then flowing straight indentation, clea Edited by user Sunday, 3 February 2008 4:43:47 AM(UTC)
" Smokem Baby " |
pacific and made in japan are def not stamped, in pic 2 just below made in japan you can see where the paint has moved a bit while still slightly wet and i dare say whatever made that mark also made the made in japan and pacific marks aswell, you can clea
the rims have been painted before by the looks. Maybe painted, then a Japanese made tube inserted? leaving forensic evidence
A1 Bogan. |
I agree with Adam. It does look as if theyve had tyres fitted while the paint was still soft. Wrong caps for a HQ too.
My Monaros:- HQ GTS 4 Monaro 350, Auto, Mustard, Black Trim - HQ GTS 4 Monaro 308, Manual, Orchid Metallic, Black Trim Edited by user Sunday, 3 February 2008 7:05:16 AM(UTC)
I agree with Adam. It does look as if they've had tyres fitted while the paint was still soft. Wrong caps for a HQ too.
I agree with Adam.I reckon they all had inner tubes installed for a long time and at the base of the valve you have the hard rubber mould that had the Pacific/made in Japan on it. Cheers...Mario
guys you are right i took to them with sand paper and rubbed them back to see if they were actually stamped on the metal the pacific has gone and also the made in japan , so definately was a tube mrks from soft paint , well at leaSt we all now know what |
" Smokem Baby " |
HQ centre caps had no tail on the lion,HJ onward had the tail. Cheers...Mario
HQ lion is the wembely lion (short tail), (egyptian lion) used from 48-end of HQ. HJ -HZ had the newer lion with a long tail. Genuine short tails are hard to find, repro decals are available.
