hey on the small block chev why does the crank pulley differ between whether you have a short or long water pump
also what bit do i need for the harmonic balancer
the 3 main bolts ??? and what is meant for the center ???
thanks
Hi dylan.
The longer water pump puts the v-pulley groove further forward, so you need a different pulley that lines up with that.
What do you mean by - "also what bit do i need for the harmonic balancer " ?
