Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
Hello, I would like to know what "real" holden straight six is best for some turbocharged action. I have a 173 sitting here but know basically nothing about the holden sixes and less about turbocharging. If I can be taught about both then that would be good. Thanks in advance, Phill
greenhj
real holden 6? there isnt much choice.. so id have to say a 202.
but an RB30 (even though it is nissan) from a VL would be better, and if you go to that much effort, you may aswell go for a toyota 2JZ.. which would have to be the best 6cyl for boost.
4/76 HJ monaroGTS |
'real' holden 6? there isnt much choice.. so id have to say a 202.
but an RB30 (even though it is nissan) from a VL would be better, and if you go to that much effort, you may aswell go for a toyota 2JZ.. which would have to be the best 6cyl for boost |
4/76 HJ monaroGTS |
202 is best for torque, while 186 revs more, im going with the 202 for my turbo project
202 is best for torque, while 186 revs more, i'm going with the 202 for my turbo project
oh, blue black motor have strongest crank (bar 3" forged) and rods. If you go for the 173, or anything smaller than the 202, go for the forged crank, standard in any pre 1967 6 cylinder. also in GTRs and 186s.
But the blue/black cranks can handle 300
Im looking at about 300 to 350 real horsepower for an eh repower, someone mentioned the sc14 toyota blower running at 10 lb is an option, what do you think?
you wont make that with an SC14 blower. go turbo, you can make even more power for nothing after setup. thats the real killer. Mine will be making 410-420hp. Are you going efi or carb?
you wont make that with an SC14 blower. go turbo, you can make even more power for nothing after setup. that's the real killer. Mine will be making 410-420hp. Are you going efi or carb?
guys its way too easy to forget that these blocks will not handle the power.
Plenty of people have extracted big numbers from a red 6...and they will tell you that they just start to tear themselves apart at around the 350 hp mark...cracks thru the lif
Im happy to go efi merely for tuning to its optimum, Im also not looking for a strip animal (I have another car for that) I just want something with a bit of poke for a cruiser. I figure a pretty tuff aspirated 6 will make 300, so with boost being the pow
Famous US enging builder Smokey Yuknic pulled 1000 HP out of a 210 chev (very simular to holden 6)
A1 Bogan. |
there are 202s running nearly 600hp that haven't had a problem, but they have blue/black blocks, so i'm not sure there.
I'd love to know more about that guys setup adam, got any more info?
there are 202s running nearly 600hp that havent had a problem, but they have blue/black blocks, so im not sure there.
Id love to know more about that guys setup adam, got any more info?
My 202 with Eaton M90 blower running 6psi boost, straight LPG. It got 120kw at the rear wheels, and 583 Nm of torque. I'm happy with it. Idles at 700rpm as quiet as you please like any well tuned Holden 6, but will easily turn the back wheels as low as 20 |
My 202 with Eaton M90 blower running 6psi boost, straight LPG. It got 120kw at the rear wheels, and 583 Nm of torque. Im happy with it. Idles at 700rpm as quiet as you please like any well tuned Holden 6, but will easily turn the back wheels as low as 200 |
The M90 is a little bit different to the SC14, it's a much better blower, and flows heaps better.
quote: Originally posted by peter_sm
The M90 is a little bit different to the SC14, its a much better blower, and flows heaps better.
quote: Originally posted by peter_smo
Got a better idea for you, and ive said it here before. Look around at Chev truck wreckers and get a 292 Chevy straight 6. Looks just like a 202 if painted up right - enough to fool anyone looking from a distance, especially with turbo plumbing. Best bit |
Got a better idea for you, and i've said it here before. Look around at Chev truck wreckers and get a 292 Chevy straight 6. Looks just like a 202 if painted up right - enough to fool anyone looking from a distance, especially with turbo plumbing. Best bit |
