4 Pages<1234>
adam PERTH Offline
#21 Posted : Friday, 8 February 2008 6:46:00 AM(UTC)
adam PERTH
Great idea Bryon!
the 1000 HP 210 chev ran on alcohol and was stroked.
thats all that was mentioned.
A1 Bogan.
boom Offline
#22 Posted : Friday, 8 February 2008 7:24:56 AM(UTC)
boom
292 sounds great, but if you were going to do an engine conversion like that, i'd be going with a stroked holden/chev V8.
boom Offline
#23 Posted : Friday, 8 February 2008 7:24:56 AM(UTC)
boom
292 sounds great, but if you were going to do an engine conversion like that, id be going with a stroked holden/chev V8.
#24 Posted : Friday, 8 February 2008 7:31:18 AM(UTC)
Sort of agree, but I was talking about a better alternative to trying to extract bulk power from a 202. The 292 will handle 250hp plus without self destructing, and it makes for an easier gearbox choice which you'd have to change with a turbo 202 anyway.
#25 Posted : Friday, 8 February 2008 7:31:18 AM(UTC)
Sort of agree, but I was talking about a better alternative to trying to extract bulk power from a 202. The 292 will handle 250hp plus without self destructing, and it makes for an easier gearbox choice which youd have to change with a turbo 202 anyway. A
adam PERTH Offline
#26 Posted : Friday, 8 February 2008 11:01:32 AM(UTC)
adam PERTH
i see that Ian King Chevrolet is doing 292 longs for $500 suit reco.
the parts would be cheap too i imagine to rebuild it.
i know what you mean about going for a 350 or simular , boom.
but it would make good sense in a LC/ LJ, EJ - HR sort of thing t
#27 Posted : Friday, 8 February 2008 4:10:28 PM(UTC)
Id go for the V8 too normally. But if I decided that a 6cyl was for me AND I wanted serious, reliable grunt the 292 is an obvious choice. A 265 Hemi is probably a better choice but is a lot more work compared to the almost bolt in 292. They are a really g
#28 Posted : Friday, 8 February 2008 4:10:28 PM(UTC)
I'd go for the V8 too normally. But if I decided that a 6cyl was for me AND I wanted serious, reliable grunt the 292 is an obvious choice. A 265 Hemi is probably a better choice but is a lot more work compared to the almost bolt in 292. They are a really
boom Offline
#29 Posted : Saturday, 9 February 2008 2:24:00 AM(UTC)
boom
really, if you are looking at a six cylinder for reliable grunt, you can't go past the 1JZ/@JZ family of toyota engines, possibly the worlds best factory six, they can make enough power to run tens with the stock internals, and turbocharger.
boom Offline
#30 Posted : Saturday, 9 February 2008 2:24:00 AM(UTC)
boom
really, if you are looking at a six cylinder for reliable grunt, you cant go past the 1JZ/@JZ family of toyota engines, possibly the worlds best factory six, they can make enough power to run tens with the stock internals, and turbocharger.
#31 Posted : Saturday, 9 February 2008 3:02:04 AM(UTC)
Personally I'd rather the Nissan engine out of a GTR. But none of those are old school, and again much more difficult to fit than a 292. A Turbo 292 is probably easier than a Turbo 202 as there isn't much bottom end beefing up required and zero mucking ar
#32 Posted : Saturday, 9 February 2008 3:02:04 AM(UTC)
Personally Id rather the Nissan engine out of a GTR. But none of those are old school, and again much more difficult to fit than a 292. A Turbo 292 is probably easier than a Turbo 202 as there isnt much bottom end beefing up required and zero mucking arou
boom Offline
#33 Posted : Saturday, 9 February 2008 3:28:15 AM(UTC)
boom
the only bottom end beefing up required is a set of ACL race series pistons, which are common in most rebuilds anyway, but you are right about the conversion part, and gearbox choice. although a supra R154 box, is almost bulletproof behind a 1jz/2jz and t
Edited by user Saturday, 9 February 2008 3:41:28 AM(UTC)  | Reason: Not specified
#34 Posted : Saturday, 9 February 2008 4:25:04 AM(UTC)
Hi all, Well it looks like some good info here, Ive been doing some research on the 292, looks like a good out of the ordinary solution, cubes and strength in a similar looking engine. I really wanted to do the v8 thing but cost and engineering has somewh
vintageholden Offline
#35 Posted : Saturday, 9 February 2008 4:40:44 AM(UTC)
vintageholden
boom Offline
#36 Posted : Saturday, 9 February 2008 5:11:06 AM(UTC)
boom
judging by your name, i'm guessing it's going into an HJ, if so, it won't be a problem, i'm guessing it weighs slightly more than a 308, but less than a 350, which are fine in HJs. either way, it's nothing a set of stiff springs can't fix, if anything at
boom Offline
#37 Posted : Saturday, 9 February 2008 5:11:06 AM(UTC)
boom
judging by your name, im guessing its going into an HJ, if so, it wont be a problem, im guessing it weighs slightly more than a 308, but less than a 350, which are fine in HJs. either way, its nothing a set of stiff springs cant fix, if anything at all.
#38 Posted : Saturday, 9 February 2008 7:04:26 AM(UTC)
Just remember that anything above 200hp out of a 202 is hand grenade territory. You can spend big bucks on customs rods, steel caps etc but that is what im getting at, with a 292 there is no need to. Due to the long stroke there is no need for big revs to
#39 Posted : Saturday, 9 February 2008 7:04:26 AM(UTC)
Just remember that anything above 200hp out of a 202 is hand grenade territory. You can spend big bucks on customs rods, steel caps etc but that is what i'm getting at, with a 292 there is no need to. Due to the long stroke there is no need for big revs t
#40 Posted : Saturday, 9 February 2008 7:19:57 AM(UTC)
Hi again, Ill have a look at those links on the 292 thanks Byron. Boom, it most certainly is not going in the Hj, the engine in that is a 355 holden making near enough to 500 ponies, hence the grumpy nature when cruising. The donor car is an EH prem, my
Guest (18)
4 Pages<1234>
This page was generated in 0.082 seconds.
