bundybluedog Offline
#1 Posted : Friday, 8 February 2008 9:24:16 PM(UTC)
bundybluedog
Gday i was given an old 308 sort block with no engine numbers on it, do i have to find an dead 308 block and use them numbers or will the RTA put there own numbers on it.
#2 Posted : Friday, 8 February 2008 10:17:46 PM(UTC)
The legal way to do it is have the RTA send you to the Police for a Police allocated number. This is normally done when you present it for registration or inspection for an engine number change. Also looks like crap as it's not easy to stamp on an assembl
#3 Posted : Friday, 8 February 2008 10:17:46 PM(UTC)
The legal way to do it is have the RTA send you to the Police for a Police allocated number. This is normally done when you present it for registration or inspection for an engine number change. Also looks like crap as its not easy to stamp on an assemble
#4 Posted : Friday, 8 February 2008 11:55:24 PM(UTC)
if the numbers can be restamped easily, how would you know if the motor in your car is original or not?
adam PERTH Offline
#5 Posted : Saturday, 9 February 2008 1:07:36 AM(UTC)
adam PERTH
its not that easy to restamp, unless you have the stamps.
also the casting date on the block should match the period of the number.
i recently had a guy try to sell me a JP block for $2000,
cheap, you would say.
but, the casting of the block was 19
#6 Posted : Saturday, 9 February 2008 2:30:46 AM(UTC)
what if u had an engine that was previously stamped by someone and you go to register your car and find out that its already registered?
#7 Posted : Saturday, 9 February 2008 2:58:56 AM(UTC)
Then someone is in trouble. If it ended up in court then with the help of an "expert" witness you would probably be OK if you had the original as the other block would have an incorrect casting date. I got offered a standard bore 327 the other day but som
boom Offline
#8 Posted : Saturday, 9 February 2008 3:18:57 AM(UTC)
boom
they picked the wrong man to mess with, but i wonder how many other people have been conned like this.
Edited by user Saturday, 9 February 2008 3:21:21 AM(UTC)  | Reason: Not specified
boom Offline
#9 Posted : Saturday, 9 February 2008 3:18:57 AM(UTC)
boom
#10 Posted : Saturday, 9 February 2008 6:34:52 AM(UTC)
It was no con. It was how it was bought. It must have been done at some stage before the current owner. To him it was just a SBC.
#11 Posted : Saturday, 9 February 2008 7:39:13 AM(UTC)
bundybluedog
thanks guys
#12 Posted : Wednesday, 20 August 2008 6:29:09 AM(UTC)
bundybluedog
does it matter which side they stamp it when the new number goes on? or does it have to stay on the same side?
#13 Posted : Wednesday, 20 August 2008 6:06:31 PM(UTC)
It should, although Police issued numbers can go anywhere as they are a legitimate restamp.
