3 Pages123>
bundybluedog Offline
#1 Posted : Monday, 11 February 2008 7:24:14 AM(UTC)
bundybluedog
Gday all ive started another project hq 1 tonner which i hope to have on the road in about 2 months and i have only ever had V8 holden or chev engines in my cars and never had a 6. So with my wife in a 6 cyl and my monaro project an 8, i figured to keep my massive bills down a bit ill go the 6. I wanna build a nice streeter that will be able to keep it with a stock 308 or better and wanna know off you guys whats the way to go. have been told the 186 is smoother and revs better then been told the 202 has more torque.
Would like to hear some tested and proven hot sixes you guys may have or had?
Triple carbs, hot cams, diferant heads maybe piston compressions?
will be to suit premuim unleaded will have a 3.55 diff and running a borg warner 5 speed.
cheers dan
Edited by user Monday, 11 February 2008 7:29:23 AM(UTC)  | Reason: Not specified
#2 Posted : Monday, 11 February 2008 7:46:33 AM(UTC)
Was thanked: 612 time(s) in 579 post(s)
Dan
Any of those combos you described will probably use as much fuel as a small V8 and cost more to build. If you want 6cyl power and good economy why not consider an EFI engine (ie VN/VP)? A V8 VN/VP conversion is easier and cheaper but the V6s are ev
#3 Posted : Monday, 11 February 2008 7:46:33 AM(UTC)
Dan
Any of those combos you described will probably use as much fuel as a small V8 and cost more to build. If you want 6cyl power and good economy why not consider an EFI engine (ie VN/VP)? A V8 VN/VP conversion is easier and cheaper but the V6's are e
boom Offline
#4 Posted : Monday, 11 February 2008 7:50:33 AM(UTC)
boom
go V8 stroker. 355/383. supposedly use less fuel because of all the usable torque down low. kits are $1950 (355) $2200 (383) from come. (displacements quoted are with a 308/304 block with a 30thou overbore.)
If nissan motorsport is
vintageholden Offline
#5 Posted : Monday, 11 February 2008 7:54:44 AM(UTC)
vintageholden
go straight lpg......high comp motor.. efi manifold from vk..Definitely grab a vk-efi inlet. anything else is very silly on a blue motor on lpg. Simply pluck the injectors, and put some plugs in there, taped ones, or weld the holes
black head 40thou..10
Edited by user Monday, 11 February 2008 8:05:20 AM(UTC)  | Reason: Not specified
#6 Posted : Monday, 11 February 2008 8:00:53 AM(UTC)
bundybluedog
es i had a look at tripple su's on ebay and they are petty expensive, i have a 308 and trimatic in my shed aswell as a 283 chev so i havent ruled out the 8 option fully yet. It just my ever nagging wife wife that always says "another bloody V8" so when i
Edited by user Monday, 11 February 2008 8:02:20 AM(UTC)  | Reason: Not specified
#7 Posted : Monday, 11 February 2008 8:00:53 AM(UTC)
bundybluedog
es i had a look at tripple sus on ebay and they are petty expensive, i have a 308 and trimatic in my shed aswell as a 283 chev so i havent ruled out the 8 option fully yet. It just my ever nagging wife wife that always says "another bloody V8" so when i t
#8 Posted : Monday, 11 February 2008 8:03:48 AM(UTC)
Yes. If not a few days from the USA, or Classic Chev in Sydney. The good thing about the 292 is it bolts straight to a Chev pattern bellhousing. See the recent posts by Greenhj. But the 283 would probably use less fuel. The 292 will kill a 308 in torque,
Edited by user Monday, 11 February 2008 8:10:44 AM(UTC)  | Reason: Not specified
#9 Posted : Monday, 11 February 2008 8:07:34 AM(UTC)
bundybluedog
vintageholden, could that combo run dual fuel or LPG only?
boom Offline
#10 Posted : Monday, 11 February 2008 8:09:35 AM(UTC)
boom
just go the stroker V8 and tell her that it's more economical because you put a polariser on the windscreen. hehe
boom Offline
#11 Posted : Monday, 11 February 2008 8:09:35 AM(UTC)
boom
just go the stroker V8 and tell her that its more economical because you put a polariser on the windscreen. hehe
boom Offline
#12 Posted : Monday, 11 February 2008 8:12:07 AM(UTC)
boom
straight gas only.
boom Offline
#13 Posted : Monday, 11 February 2008 8:12:07 AM(UTC)
boom
straight gas only.
#14 Posted : Monday, 11 February 2008 8:21:46 AM(UTC)
bundybluedog
unfortunaly the stroker will break my budget, I cant believe i am starting to worry about the economy of an engine i never have before!! OK economy pushed aside and keeping it to 6 cylinders. sorry boom save the stroker and wild V8 topic for when my monar
#15 Posted : Monday, 11 February 2008 9:27:48 AM(UTC)
bundybluedog
byron you say blue/block motor crank and rods. are they alot stronger?
Edited by user Monday, 11 February 2008 9:28:46 AM(UTC)  | Reason: Not specified
#16 Posted : Monday, 11 February 2008 9:48:31 AM(UTC)
vintageholden
lpg only
or get a gas hat........lpg only is much better.....
blue and black motors use starfire rods.....dont get the ones on ebay...
i thought you were trying to save money by going 6 ??????
why are people suggesting V8?????
292 chev is a truck mo
#17 Posted : Monday, 11 February 2008 9:56:02 AM(UTC)
vintageholden
#18 Posted : Monday, 11 February 2008 10:13:08 AM(UTC)
bundybluedog
Yeah i guess wanting the engine to perform and keeping the economy dont really go together do they if i want it to remain a carby fed holden 6? Does running straight gas shorten your engine life? was told that the valves do not get the luberication they n
#19 Posted : Monday, 11 February 2008 3:26:45 PM(UTC)
vintageholden
get gas seats or run valve saver there is one in a bottle that fixes to the motor and feeds into inlet manifold
http://cgi.ebay.com.au/M...72469QQtcZphotoQQssPageN
Edited by user Monday, 11 February 2008 3:28:52 PM(UTC)  | Reason: Not specified
#20 Posted : Monday, 11 February 2008 4:10:14 PM(UTC)
Guest (12)
3 Pages123>
